Warspite gets a few scars
Hi all I made a start on what is going to be a massive project in which HMS Warspite is involved in an air attack by the Germans.
I will be using Academy’s 1/350 Warspite and several other scales of model aircraft also will be using led’s for the explosions and lighting the water spurts from near misses with bombs.
I wont be getting the Warspite till my birthday in roughly a fortnight but have made a start on the base and some of the planes I will be using.
Here are some picks of where I am at, at the moment.
the smallest bombers are 1/350 scale kindly donated to this project the 1/144 stuka’s are zevada
the 1/72 Stuka in the process of being built is Academy and I have a 1/72 Airfix FW190 to go on the Dio too.
as you can see it will be a long term project.
Hi all here is a little update on the Stuka
I have realised from the pic on the box I have bought the wrong version, the one I’ve bought is the anti tank one, which, apparently has no dive brakes and no bomb cradle.
I have tried to make the air brakes (I could only find one decent pic of them and that was on a model) I have no idea what they really look like so this is my best attempt at what I could seen. as for the bomb cradle would that have swung back up after dropping its payload as I obviously dont have a bomb so I want to do it as if its just got rid of it.
I have glued the windscreen on before it says so in the instructions as I got tired of rescuing them from the CM after breaking them off, seemingly every single time i picked it up, Hope that decision dosent end up biteing me in the bum
Also made a start on the FW190
Look what I got today
Not allowed to start it till my birthday though(mind you I wasn’t allowed to open it before my birthday)
Pretty ambitious project you have going on there [Y]
Well here is a progress report of todays work the guns are back on the Ju87 and have done a bit more work on that and the FW190.
Hi all done some work on the FW190
Here is tonights bit on the planes
Hi all got some paints for this dio delivered today
Its amazing how much paint you need for something like this, as far as I can work out I still need another 11 colours.
and did some work on the stuka
Hi all an update on the the planes
did a bit of work to try and make this look like a He 111
did some work on the FW 190
and here is a shot of all the attacking planes I will be using
hi all here is quite a big update, I have tried my first attempt at panel lines and weathering of a plane, also I have been experimenting with the explosion on the Fw 190 wing
the explosion is a bit too orange so will have to either add some brown or blue to it then a bit more black to the smoke, still got to add the suspension strutt and the cover thingy that goes over the wheel will have to buckle that a bit and bend the suspension strutt but I think the explosion should work ok.
Very cool!!
Well its not my birthday till Sunday but I am busy most of the day tomorrow and we have the whole family round Sunday, so I’ve negotiated a start today on my Warspite model so here is the start.
I have placed a few planes and Warspite in different places which do you think looks best (obviously the planes will be in the air on the finished dio) I just want an idea of which you all think looks best.
Hi all made a really stupid total nitwit mistake in my eagerness to start this kit. There are parts on the deck you are supposed to cut off before you attatch the wooden decking, which I didn’t. That made the job of removing it now a real b@'!:er, still done it now I’ve bitten the bullet and done a tiny amount of PE (the gangway which goes across the bow there are 2 gussets underneath which measure 2.5mm x 1.5 mm after an hour of getting them in the right place and upright I have to wonder is it worth the effort, once it’s on the dio no one will see it, even off the ship when turned upside down you can barely see it with the naked eye. Still we will see how long I keep the PE up as although they are small the gangway was a simple bend the sides up (oh by the way the Mk1 detail up set instructions are vague to say the least) they show a picture of the part in place and one pic of some of the folds you are left to guess the rest of the folds.
Hi all here is a bit of an update of where I am now.
I am a bit peeved now, I realise I made the mistake with not removing the plastic before I laid the decking but now i’ve started putting the PE on I’ve discovered ther are other bit which should be removed which are not on the instructions and now i’ve laid the wooden decking and cut it to fit whats on the deck the PE is not covering all the plastic.
as you can see from the pic the only part outlined is the gangway which is to be removed but as i’ve now discovered the ramps should have been removed too.
as you can see the PE ramps are too short and I can’t remove the plastic ramps as I’ve cut the decking to fit, so I’m hoping that when painted grey it wont notice. (yes I know the middle blast shield is crooked in the pic but that has been sorted now)
led in place ready for the only direct hit on the poor old lady.
I know I swore I would never use PE again but this is all fairly simple stick it on stuff at the moment so will stick with it for now.
first start at the explosion and I thought I would try an experiment with Optic Fibres will bee using those for the tracer rounds Warspie will be firing, I have discovered if you scratch the firbre every so often light escapes at the scratches over a length of about 12 inches (it does gradually get less as it goes along but I think 12 inches will be enough for me) anyway keeping it straight at anything more than that is almost impossible
Obviously there is no smoke yet nor any debris in the explosion , I am wondering whether to put an unfortunate sailor in the smoke of the exlposion sans a limb or 2 ( the 350 scale sailors I’ve got I’m not sure it would notice, but might be fun to see if anyone does).
That looks fantastic!!!
Hi all I think I’ve got too many balls in the air at once, at the moment so I am going to finish some of the planes before I get too involved with Warspite, so got on with the FW 190 and apart from painting the canopy and matt coating it I am calling the 190 done.
I’ve done the all the decals on one side of the JU 87 so I recon that will be ready for matt coating tomorrow.
Hi all here is an update, and a querey I have used humbrol matt varnish for the first time, But I have an unusual effect the varnish has white patches (which in this instance is great I was going to add something like this anyway, and think it works ok) but what if I didn’t want it, whats gone wrong ( I stirred it thourgherly)
Hi I’m new to this party. Is this an actual event? I’m curious to know time and place.
Hi GMorrison she was involved in several attacks but I am using a bit of artistic license I can’t fit 118s on my dio just don’t have the room so as I said am using artistic licdnse, and since there is no one who can challenge my version, this is just how I envisage an attack on warspite.
doing some work on the base today
as you can see not a lot of room in my man cave for it
drilled the holes for all the leds and put and wired the leds into the board
not wired the explosion in the stern of warspite cant do that till Warspite hull is permanently atattched same for the FW 190
the 2 blue leds are for the water plumes for the near misses.
