Vision M1A1 75mm Pack, WIP, 1/31/10, Complete
Off onto a new “fire mission”! This will be the M1A1 75mm pack howitzer, the little gun that did. For this build I will use the new Vision M1A1 kit along with the old Verlinden 75mm ammunition set for the M8 and the M1A1 pack.
Orejohn was kind enough to send me a copy of a family photo, taken during Operation Market Garden. You can see the gliders in the background. I will be using this as the concept of my build.
The kit is straight forward and consists of one full sprue and a small sprue. Also included is a metal end for the barrel. The instructions are simple line drawings with some written explanation. Also included is a color photo sheet of a M1A1 up close with some details.
Step one is the assembly of the barrel and recoil assembly. There is a choice of two sights, one if the tube is elevated and the other if the tube is down. I will leave the sights along with the block off for now. Here is the assembled barrel
Step 2 is the assembly of the rear section of the carriage which includes the spade. Some of the parts in this assembly have some bad ejector pin marks which best worked on prior to assembly. With the pin marks sealed, here is the rear section.
Step three is for a post WWII modification which I will skip and steps 4 & 5 assemble the front carriage and mate it to the rear section. Here again there are the ejector pin marks which needed to be filled first. With the filling done here is the lower carriage.
Step six assembles the axel and wheels. I have left the wheels off for painting, but here are the major assemblies.
In general the kit is a great little kit and in many ways an improvement on many of the resin copies. There are two sets of wheels, either military tread or civilian tread, both were used in WWII. The kit also comes with ammunition but no crates or fiber cans. That is where the Verlinden set is a must. There is also a resin set now out to convert the kit to British airborne and has airdrop containers both US and British.
The draw back is the molding which reminds me of Renwal from the 70s. The kit is detailed but pin marks and lots of little flash. Even the plastic is much like the old kits, harder and a bit more brittle.
Time for DETAILS…now you did not think I would go OOB!
Many parts on the 1 to 1 scale barrel and recoil assembly were cast. With that in mind, I set out to texture all those parts on the model with Mr. Surfacer 500. This is mostly the upper barrel shield and the lower recoil assembly.
The carriage frames on the 1 to 1 were essentially two C channels welded together to form a box. The front part of the carriage boxes has the equilibrators inside the box which are molded in on the kit. To get the weld bead on the model, I used Archer small weld bead. In the case of the model it solved two problems, putting the weld bead on and coving the seam on the forward halves
The kit has a molded on the side data plate but the only detail is the outside ring. The actual data plate is a raised oval plate. To create the proper effect, I filled the ring with Mr. Surfacer Liquid Putty. This created the proper raised surface plate.
The stub for the metal barrel which comes with the kit is just a small section of brass tube. To improve the barrel, I added PE rifling inside the barrel. The rifling is from an old OOP PE rifling set from On the Mark Models I picked up on e-bay. It comes in handy for these situations.
The breech is fairly well made and detailed except for one problem. It is one piece both breech and block and is molded in the closed position. But there is a hole right through the block like it was open. To correct this problem, I punched a disc from styrene sheet and fit it to the hole. Fortunately the real deal has a round cover plate on the block which accesses the hammer mechanism, so this fix also adds to the block detail.
Next up will be priming, painting and then final assembly. This little guy should go fast. I will be in the spray booth but should have assembled pictures next update.
As always, all you comments are always appreciated. Thanks for stopping in
Rounds Complete!!
That was a quick shift-to-fire-time. Must be a planned target. Good job so far. I built the old S-Model resin one a few years ago. This one look much better. Keep up the fire!!
This kit is sure building up quickly, nevertheless it looks great so far! Will definately be following to see how this one turns out.[H]
Gino - As an artilleryman, all my build targets are planned!!! Yep needed a little quick build after the M40. I have a resin copy also on the shelf. The detail on this kit is a bit more crisp than the resin versions.
Thanks for stopping in!!.
MG - Thanks for stopping by. This little guy builds fast and is great for a quick build!!
Rounds Complete!!
Nice work on the little gun there Mike, the Archer weld beads and other details/fixes you’ve been adding are up to your usual standard of attention to detail! Looking forward to seeing this one get emplaced and ready for action. [Y]
Bill - Thanks…Details…I would not have it any other way…even with the little guy!!
Rounds Complete!!
Howdy redleg,
glad to see you modelling. And the way it’s done - it’s a pleasure to see you building the model like telling a story and you really know what you are talking about. Keep 'em coming and have a nice day
Pawel
Pawel - Thanks for the comments. Glad you enjoy the work in progress builds.
Rounds Complete!!
I figured it wouldn’t be long before you tackled this little guy, Redleg!
She looks good so far.
Thanks again for the advice on mine.
Cant wait ta see the final result!
I’ll keep the radio ready for your first fire mission…
Tom F.
Big or small…the hope is one day to have built them all!!!
Thanks for stopping by and staying in the loop
Rounds Complete!!
I’m keeping an eye on this Mike because I see them on the Military Channel a lot.[H]
Tony Lee
Mike looking good. Your extra work always makes your builds shine and this one is no exception.
So will this guy be known as ‘Little Bruiser’[;)]
Tony - This little guy is on almost every army post. Check at the post flagpole…it usaully gets to fire twice a day!! I have a resin copy of the 75mm…at some point I am going to model the flagpole!
Thanks for stopping in.
Steve - Hummm…how about “cajones”…“little thunder”…bruiser just does not fit [*-)].
Thanks for making the stop. You know me…I love details!!!
Rounds Complete!!
Hey Mike,
This little guy looks amazing with your usual attention to detail.
Somewhere in the stash I have the old Tamiya white metal kit… [proplr].
Phil - Thanks
The good part about this kit is you don’t have to deal with the metal assembly. I am sure most resin kits are copies…somewhat…of the Tamiya kit. It would be interesting to build this kit alonside a good resin kit and the old Tamiya kit and note the differences!!
Rounds Complete!!
Howdy Mike,
I too will be watching this build… as I do with all of your builds! I have also built the Tamiya metal kit and I have converted the Roy Models kit into the M98 HOWTAR and it will be intersting to see the comparisions to Vision’s kit.
http://www.mortarsinminiature.com/USM98.htm (about half-way down if needed.)
As usual, lovin’ every step of the way!
I’m glad to follow this one. Your builds are always a joy to follow though, sometimes painful. That is in reference to the tracks on your M40. I don’t mean to bring up any PTSD around it but that was painful to see.
Anywho, the detail on this one looks exquisite, not to mention what you’ve added.
Cheers
Dave
Kevin - HOLY EXCREMENT…It’s great to see you…Love the M98 conversion…neat toy. Thanks for stopping in and the comments. Always a pleasure to see your stuff and to have you “hang a round” [;)]
Dave - Yep…I am still recovering PTTSD…Post Track …Syndrome. Stuff happens. This build is relitivly painless. Busy at work this week but hoping to finish up this weekend!!
The kit detail is nice. The good thing is on the small size, the details are not muted like some of the resin copies.
Rounds Complete!!
This was a tough week but I was able to get the work completed on the weekend.
After priming with Tamiya Flat Black, the main parts of the model were painted with PolyScale OD 505370. Tires are 50/50 Tamiya Flat Black and NATO Black. Breech is Alclad Steel and the block is Alclad Aluminum.
I prepared a simple base with the dug out for the spade. Then it was time for the details. The ammo crates are painted with Tamiya Dark Yellow with the handles Flat Black, Flat White on the side supports, and Alclad Aluminum for the hardware finished with custom lot markings for the sides. The ammunition fibers are painted with Tamiya Flat Black.
Dunnage….the empty shell casings are painted with Alclad Pale Gold. The inside of the casings were painted with Tamiya Flat Black.
After the crates were glued in place I made a tarp with aircraft tissue soaked in landscape cement and laid in place. After shaping and drying, the tarp was painted with Vallejo Olive Drab. After the paint dried the tarp was weathered with MIG pigments Dry Mud, and Old Rust.
The prepared ammunition was painted with Alclad Pale Gold for the casing, Tamiya OD for the shell and Alclad Burnt Magnesium for the fuse. The ramming staff is Tamiya OD and the bore brush is Tamiya Flat Black, while the eyebolt and brush holder is Alclad Steel.
Also at this point the howitzer has been weathered with a pin wash MIG Wash for Dark Green and then MIG pigments Dry Mud and Old Rust.
Lastly….the lanyard (PSGGB)….using ship builder’s waxed string painted with Tamiya OD. The end ball fabricated from styrene rod.
With all that here it is the finished M1A1 75mm pack howitzer.
Up next M752 Lance Missile Launcher….all resin kit!
Rounds Complete!!
EOM
She is an absolute beauty Redleg! I am always happy to see your arty builds to break up all the armor builds from time to time. Great job!
Brian
