Vinyl models
I just bought a 1:1 scale T-800 endoskull from the terminator I also bought a model of boba fett, They’re both vinyl kits, is there anything I need to be aware of before I start these? Special glu/paints or anything? Thanks- Pat
They need to be washed and primed, then you can use any paint and technique you want.
Prime with a paint that does not react to vinyl, best are acrlics
what about the alclad laquers will that react to the vinyl?
I have no idea, you might try painting some on scrap vinyl from your kit and find out, try some with a primer underneath also
