Hi Chris. It’s 1/72. One of those adventures in modeling. I was knocking around a hobby shop at lunch and found a big dusty plain brown cardboard box stashed away on a high shelf. Pulled it down, it was all taped up and had a photocopy of the first page of the instructions clear taped on one end. Some fairly ominous statements about “no landing gear, no propellers”. The “definitive 1/72 census” site (72scale.com) lists it as built by “Gene Cooper”.
So after a short “bet it’s been there a while, don’t you want to make room for another P-51 kit?” negotiation, I soon find myself parked on a lonely alley tearing open the thing.
Three really big vacform sheets and clear vac canopy section. And a big fat envelope containing a stapled instruction set and a nice set of window decals, and a not so nice set of TCA decals. The instructions are pretty thorough and have a full set of patterns to build what is basically a balsa and spruce airframe onto which to skin the plastic.
Now mind, in my infinite ignorance I had not even heard of Vanguards before, sorry chaps, but in the last 24 hours I’ve learned a bunch. Until I find that 1/72 Comet this may be the next best thing. Of course there is that Caravelle in the stash… but I digress.
But I also know my limitations. I’m not good enough or patient enough or have time enough to take on basically a big molded/scratchbuild project.
So here’s my plan of action:
Fuse- pretty straight forward. Whether or not I build a wood form is a question, I seem to remember an article about using expanding urethane foam to fill big vacs. I’d need to make a spar and close the bottom between the wings. And I’ll paint the cockpit glazing for sure.
Wings- the kits’ are not going to work for me. No molded lines period, including flaps or ailerons. Just big smooth blobs. Panel definition is easy, scratchbuilding control surfaces isn’t. So I kind of hope that the Viscount wings work. I’m going to try to get my hands on some drawings, and as always any advice is welcome. I’m sure it’s a longshot. Ditto tailplanes.
Gear, props and BEA decals all from a Viscount I think. Also nice BEA decals available AM.
So before I sink more $$ into this I’m off to the research division.
Cheers, Bill
