Verlinden Jolly Roger Help
I’m starting to tinker around with Verlinden Jolly Roger, has anyone done this kit? This is my first resin kit but that has little to do with my problem, there was no kind of instructions included and I am confused as far as how the 5 neck vertabrae go together, they are numbered 1-5 but do not seem to fit together in any particular way.
So I guess my question is, since the pieces are numbered, does that mean they go together in that sequence and if so would #1 be at the base of the skull (top) or at the bottom? I have tried to set these pieces together and discern some kind of fit, but it doesn’t seem to be obvious.
Any ideas from experienced Verlinden modelers would be welcome, especially if you has built this figure and figured your way through this area of construction.
