Not sure what caused the spotting but I find the best results are obtained when you apply the distilled water thinned Vallejo OVER a suitable lacquer or enamel primer. I use Tamiya Primer which provides a great base for the Vallejo acrylics. This prevents them coming away from the bare plastic as you described.
My 1:72 Airfix Gnat brushpainted with Vallejo over brushpainted Humbrol Lt Grey enamel. The gloss was obtained using Future.
Bro ya gotta sand the plastic with a very fine grade or Those vallejo’s wont stick. A primer is good but not neccessary if ya sand the model first. Don’t forget to wash the model before painting. I have switched to Vallejo’s and love em. DO you notice how little you need to thin them… I think its great. Have you seen the model air line yet?? Made for the airbrush. I havent tried them but my LHS stocks the whole line.
Ooo forgot to add… you didnt mix the paint enough. Thats why you have black there. Shake those Vallejo’s HARD for a while. That’s how I get my finishes with them.
Jeff, I sanded the entire model with 1000 grade wet & dry, as I had to remove a pebbly finish from the surface prior to painting, so the surface should have been properly keyed.
Maybe I didn’t stir it enough before applying, that would explain the black marks.
I saw the AB ready paints on Vallajo’s website, but I don’t think that they are available over here. Having said that, even if they were, you know how I feel about my Gunze!
I’ll try a coat of Gunze white before I put on the Vallejo next time.
Karl
I use Citadel Miniatures Chaos White spray cans for priming.
Then I spray Vallejo using a 2:1 paint :water ratio - this gives me the best results.
My LHS recently started stocking Vallejo Model Air pre thinned paint , but I havn’t tried it yet.
