USS Gato colours
[8]Well the Engle kit of the Gato arrived the other day, all six feet of it! The only problem is that the instructions only give one colour scheme, Black.
The photos that I have been able to obtain show light verticals and dark horizontals. I would assume haze grey and deck blue but I have a feeling that in some areas the horizontals were green.
Can anyone assist.
Thanks
Dai.
Hey Dai,
You have two choices…this is taken right from the Ships-2 manual, June '42 Revision Supplement. There has been some talk that some US subs may have carried Measure 23, but I’ve yet to find any evidence of it… Jeff
Ms 9: Black System for Subs. Vertical Surfaces:
Paint entire submarine above the waterline black, formula 82. The painting shall be carried over all parts which are visible for the air including the numbers, capstan and running light boards and bridge rails. The radio insulators shall be dark. There shall be no boot topping. The underbody shall be painted with the current issues of bottom antifouling paints.
Horizontal Surfaces:
All horizontal surfaces except wood decks shall be painted Dark Gray 5-D. The systems differ only in the painting of the vertical surfaces. In case of doubt, as on sloping surfaces, use Dark Gray 5-D.
Notes:
The camouflage painting need not be exact or carried into corners. Small gear, wires, rigging, and areas permanently in shadow, as under boats, etc., need not be painted with the camouflage colors. There is no objection to exact or careful painting which may be desired for the sake of good appearance at close range.
All bright or shiny objects, no matter how insignificant, shall be painted, covered, or removed.
Glass windows shall be covered or removed, especially during the day in sunny weather, and at night when anticipating searchlight discovery. Insofar as conditions permit, similar precautions shall be taken on airport lenses.
Ms 10: Gray System for Subs. All Surfaces:
Paint entire submarine above the waterline Ocean Gray 5-O. The painting shall be carried over all parts which are visible for the air including the numbers, capstan and running light boards and bridge rails.
Notes:
Exposed brightwork shall be painted to harmonize with the exterior of the ship.
All Glass windows shall be removed, rolled down, or covered, unless conditions are such that light reflection from their surface is unknown. Insofar as conditions permit, similar precautions shall be used on airport lenses.
All Canvas covers shall be colored to match adjacent ship paint.
Raised characters, such as ships names and draft marks, shall be retained and painted the same color as the hull in that vicinity.
Decks were NOT painted 20-B, but the hull color.
Thanks for your valuable advice and insights Jeff!! I started a thread a moment ago (pearls for an old codger?) in this forum and your Gato class remarks are really helpful!! I’m not building such a remarkable model as Dai (USS Lionfish, 1/200 scale or so) but I’m following your remarks closely. Thanks/J.P.[:)]
How about pink?[:D]
Sorry Jeff, maybe I do watch too much TV.
Scott
For a couple of years, Gene Berger drove his 9 foot 3 inch long 1/32 scale R/C fleet boat in waters from Lake Trashmore, Virginia Beach to Groton, CT painted as the boat from “Operation Petticoat”. There is no way to describe the sight of a nearly 10 foot long model, painted Pepto Bismol pink, arising from beneath the surface of a pond or lake…
I believe it is now painted in Measure 23.
If I remember correctly…there’s actually some truth behind a pink sub…
Story was there was a sub at Pearl that was moored next to another sub that was on fire. The heat from the fire blistered the paint on the sub, making it less resistant to the elements. When the sub put to sea, the blistered paint, coupled with an extended cruise, actually wore away, revealing the oxide red underneath, which, when exposed to salt air and sun, turned pink.
I don’t remember where I read that…but it’s plausible.
Jeff
Thanks for the help it has been very usefull.
I found a couple of web sites by hunting the Lionfish site as indicated in the kit.
The big Gato belongs to a friend of mine, who is a Chief Engineer on a Bulkie, and is even less net literate than I. So I do the research and he gives me the plastic kits to build!
My wife is wondering where al these kits are comming from!!
Dai
