i have never used static grass. what is the most effective way to use this stuff?
apply thinned white glue to the base,
place the base in a box larget than the base,
liberally sprinlke the static grass on,
hold the base upside down over the box and tap the bottom.
blow across the grass and that’s it.
I then return the excess which is in the box to the baggie. If needed, I’ll spot apply more with tweezers and repeat steps 4 and 5.
You can further seal it with aerosol hair spray when the glue has dried.
thanks for the info. i had tried using just once before and that was after i already had other turf on the base… it did not work out the way i wanted. i think i get the idea now. thanks.
Ajlafleche pretty much covered all I know, but there is one thing. I don’t know if it works, but I’ve heard that rubbing a ballon on your head to make static charge and then lightly holding it right above or tuouching the grass makes it stand up just like your hair, giving it a more realisic and “standing up” appearance. Agai, not sure if it works, but it would look great if it did! Hope this help, and post some results!
I read somewhere that if you applied grass, then placed it on top of a television, it would get it to stand. Didn’t really work for me. It’s a shame- I’d love to be able to combine my two favorite pastimes[(-D]
SteveM
I would just add that you should buy several shades of grass - my local hobby shop has at least 6, ranging from bright golf course green to dusty prairie brown - or your diorama base is going to look rather otherworldly. Real grass is not a uniform green, not even on a golf course (much as they would want it to be!) and you need to make sure you break up the monochromatic look of the turf.
I have a piece of film (8.5 x 11 transparency film) that I rub on the dog then use to make the just applied static grass stand up. If you should only have 1 color of static grass, once dry you can make it variagated by either air brushing some color or dry brushing.
Actually I think it’s better to paint it all, since it’s shiny.
