Bought an older PZK IV at a show recently and it came with a photo etch detailing kit. I have always been an advocate of scratchbuilding details and since I’m now getting back into the hobby after a 20 year hiatus the PE stuff is new to me.
What is the best way to attach the brass details to the plastic?
CA glue sufficient or is there some other adhesive?
Super Glue. I’ve never had any luck using any other type of adhesive. Be sure to get a bottle that comes with a narrow tip, it’s easier for application on small p/e parts.
I’ve always known to use superglue but my question is this. Often times some PE sets come with all the little exterior antennas found on a given plane, helo, etc. How can I attach these knife-edged parts onto a painted kit without marring the finish too badly? I see pics of models with these tiny details on them but I never see any scraped paint, a bead of superglue, or anything like that! Is it just the camera angle which make other peoples’ models look flawless?
Depending on the type of part you can also use clear enamel paint. This works great for scripts and stuff like that, that lie flat on the surface. For antennas, etc CA would probably be your best bet.
Thanks guys, this helps.
The PE set that was with this kit is produced by Eduard. What can you tell me about other producers of PE accessories and add-ons?
