Using Micro Set-I just don’t get it
You know that’s probably a better way than using a fine brush. It allows you to apply some pressure, also I can see “rolling” the tip over the decal forcing it into panel lines for example. Thanks for the tip.
I usually choose to occasionally knock my bottles over but someone recommended this one
Ahoy Tojo72. I love it. I made a wooden rig that holds three bottles very much like your picture and scored a triple whammy by knocking three bottles over at the same time.
This is the set I bought of Etsy
Last time I did decaling (is that real a word?) I would put a drop or two of dish soap in the warm water I soaked the decals in. it helps break the surface tension allowing the decal to be moved into place easier. My understanding is the Micro-Set does basically the same thing.
The Micro-Sol, Solvaset, Mark Fit products actually melt the decal film so the decal can settle down and conform to the not-smooth surface of the model underneath.
Ahoy JF. I’ve often wondered about that myself. And is it Americon ‘dee-cal’ or British ‘dek-al’?
