Here is a small project I started while waiting for parts to dry during my M60A1 Franken-tank build.
It is a Willys DJ-5 Dispatcher Jeep. These were originally built for the USAF to use in non-tactical roles around base. They were built starting in 1955 and were basically a M38A1/CJ-5 with a new body. They were civilianized with only rear wheel drive, standard steel front bumper, large rubber bumper on the rear, fuel tank relocated to under the rear between the frame rails, civilian wheels and tires, and a few other changes.
Later versions were made by AMC with an extended grill due to a larger engine. They were later used by the USPS as delivery vehicles.
Apparently, later versions were also used by the US Army and USN for similar purposes.
I haven’t found any pics of them in USAF service, but I did find a drawing of one.
I have also found pics of similar M38A1 Air Police jeeps, so That is what I am going with.
I found a DJ-5 file on Cults3D and resized it to 1/35 and printed the pieces for it. I added these to an AFV Club M38A1 tub, chassis, and front end. I had to modify the tub by removing the gas tank under the driver and rebuilding the floor w/styrene, leaving the tool box under the passenger off, and leaving off the levers for the transfer case. I sanded the 24v battery box cover on the engine cowl off as well. I also adjusted the door openings since the 3D file had rounded openings like an M38A1/CJ-5. The DJ-5 had angled door openings. I also added the seat mounts from some left over PE parts, and added the vent covers on the front sides.
On the underside, I removed the front differential and replaced it with a styrene rod. I also removed the transfer case and cut up the rear axle to relocate the differential in the middle, as opposed to the 4WD offset. I rebuilt the drive shaft to fit as well. Lastly, I added the fuel tank behind the rear axle and added a filler tube to it coming from the filler cap on the right rear.
Here it is all mocked up to see how it will look assembled with rear door open and closed.
Here are some of the other 3D printed parts. A battery to add in the engine compartment (which will be plumbed), tires (1950s chevy 5-bolt rims and '50s tires), front and rear seats, rear bumper, and a siren. The rest of the tires are currently printing.
I plan on marking it up as a USAF Air Police jeep (like above) in USAF Strata Blue with yellow markings similar to above. More to come later.
