USAF Revetment Viet Nam 1/48th?
Does anyone know of an outfit who makes a kit of a revetment, in 1/48th scale, the AF used at bases, e.g. Phu Cat, Phan Rang, Tuy Hoa, etc, in 'Nam in the '60s and '70s? I know Verlinden makes one in 1/72nd, but I’m building up a series of F-100s in 1/48th and would like to mount them in revetments. Any assistance would be appreciated.
Dunno about who’s selling them but making them is a breeze… Probaly WAY cheaper too… Interested in that?
Hans,
I appreciate the response, but what kind of a breeze are you talking? I have considered building up revetments and have even figured out dimensions. I even have the correct color of dirt to fill them with here in mid TN. I’ve got quite a number of pics of them from the net and research books I have on the shelf. Do you have, or know where I can get, plans?
I’m talkin’ “Cool breeze, man…”. Easy money…[t$t]
No, I don’t have plans, I just use the ol’ Super-Calibrated Mk I Eyeball when building structures… I use a figure from the scale I want as a "yardstick, like for 1/48th, I figure that since the height of a standard Monogram figure is 1 1/2 inches, or 72 scale inches, I can use that to roughly measure out any structual dimensions… I mean, it’s a revetment, not a watch, so eyeballing it is close enough for government work, knowwhutImean?[t$t]
Never buy what you can build, that’s m’ motto, lol…
For the steel revetment wall-sections, I’d just build a “box” of styrene from a couple “Garage Sale”-type signs (my favorite sheet styrene source), glue strips of styrene cut form the signs on the front and sides, and then just sprinkle a litte “earth” along the top over the styrene “cap”, which I’d glue about a fat 1/8th inch down inside… Then I just keep building those boxes until I have enough to revet the entire area I’m working…
There were concrete revetments too, as well as sand-filled fuel drums too… It all depends on what you want to model… I’d make a mold-box for the concrete ones and cast them in plaster, or for the drums, make a “master” out of something like the Tamiya fuel drum set, then cast as many drum-sections in resin as I need, gluing them together and “filling” the top ones with dirt…
I certainly appreciate the input. I have the photo you included and will use it, and others, as a guide if I decide to go this route; another problem is where I’m going to put this thing. I would also like to get some fire extinguishers, oxie carts, and other bits and pieces to complete the -100. Again thanks for the information.
Found a picture of one being built that will give you a sense of scale.
Found this on another forum
On top of the revetment walls on the ends and where the walls joined another cross wall there was a sandbag fox hole. The yellow objects by the revetment opening was a bomb rack.
Tony Lee[:)]
Lots of nice info - most probably I can make a good use of it some day - so thanks for sharing and have a nice day
Paweł
I’m sure that there’s sets out there that contain some of the items you need, I think Hasegawa has one that does anyway… I’ve never seen a kit of a Huffer though, but I’ve built a couple from sheet styrene and plastic swizzle stick straws before and then used wheels from a Match box toy car on 'em…
ESCI also did a 1/48 set of ground equipment stuff. You can still find it on eBay and the other old kit sources.
Air Force Civil Engineering REDHORSE and Prime BEEF at its finest. On another note, check out model railroading stuff as I think you should be able to find plastic corrugated metal sheets that would approximate these shapes. And O scale is 1/48.
