Maybe I’m getting a bit forgetful in my old age but I have a question about what to do next. I’m building Trumpeter’s 1/32 A-6E. I have the fuselage together and painted its base colors. The inboard wings are on and I intend to have the outboard wings folded. My question is: Should I glosscote the fuselage now for decaling or should I start fading/weathering and do the decals after that? I’m thinking about decaling now but I’m not sure. Thanks,
Yes…but it doesn’t hurt to spray some more gloss over the decals, to seal them in good. That also gives you the same “canvas” as the rest of the model.
You want to make sure the decals get some weathering. If the paint is weathered, it looks funny to see pristine high contrast national insignias and other markings.
Well, what I’ve already done is apply the decals (which came out very nice BTW) and gloss coated the whole fuselage in preparation for washes. After the washes I’m going to have to figure out if I can mist a lighter color over the decals (simulated fading) and then, as a final step, dullcoat the whole plane.
What I tried today was a 50/50 mix of white with dullcote thinned by about as much thinner as there was paint in the airbrush jar. Seemed ok on the test panel, I got moderate fading of the decal I put on it the other day so I’ll probably just do what I did to the test panel.
When shading, I vary the thickness of the fading coat around the airframe. Areas that see the most sun should get the most fading. I put heaviest fading on top of fuselage and tops of wings and horizontal tail surfaces. No fading on bottoms. For the fuselage I put on max thickness on top, and keep reducing it as I come around fuselage.
