Love the photos as much as the model. I am a big advocate of realistic model photos. Most photos of models are what I call “model as art”, which uses high camera angle, flat lighting and plain background.
Realistic model photography shows the model from realistic viewing angles, sun lighting, and against realistic backgrounds. What is the model sitting on in the “tarmac” shots? It sure looks like tarmac!
A beautiful job!!! I’m curious, how do you progress through a build like this? Do you complete the detailing of the wings, engines, etc. (painting, decaling, weathering) before attaching to the fuselage, or do you do your painting and decaling with the wings and horizontal stabilizers attached (seems like this would be extremely difficult)? Whatever you’re doing, it is working!!
I almost always attach wings/stabs on last after painting fuselage. Sometimes I dont have a choice like the large Heller kits. Then wings mounted before decals/painting etc.
Decals before the weathering is done. Adding flaps/slats I’ll add to wings before fitting wings to fuselage. Engines go on after wings on fuselage. So I can check for everything is even between both sides.
