undershading panel lines
On my next airplane model, I intend to try undershading the panel lines with thinned down flat black to try to get a little depth. Is it correct technique to airbrush the undershading, or is it just as good to brush it on?
Thanks,
Rich [8D]
You can do it either way, but I would go for the AB. With brushing you have to becareful to make sure the paint is very thin, the AB can put down paint much thiner than the brush and you may have ‘ridges’ from your brush showing through a top coat that’s been Airbrushed.
