~I’'m just getting some elements going for an upcoming Diorama, the title of which at the time of this writing is " Beyond the Rhine " . As usual for me there will be a number of resin figures involved, from varied manufacturers, representing some variation in uniforms & equipment.
To say that clean-up & assembly was a breeze would be an understatement. Actually I think this is the best resin figure I’‘ve seen–even fitting both arms and the Garand with attached hands was simple, with keyed attachments for both arms, there was nearly no play, and after gluing the arms in place, the weapon/hands part can dry-fitted perfectly. I’'ll have this piece seperate for painting, and am using a small piece of clay to keep it in place here. The head is in place with a music-wire pin, and will likely be left free to turn until final placement in the Dio.
~It was really difficult to photo, as this is a extremely small detail on an uncoated part, but you can see that the hilt of the bayonet is actually drilled out to scale–a feature of detail I haven’'t seen before.
Another detail I thought was quite exquisite, was the complex Garand sling, cast as a seperate resin part, which easily fit in just the right spot.
Everthing was mounted-up on music wire ‘pins’ and sprayed with a few very ligth coats of Tamiya TS-3 Dark Yellow as a primer/basecoat
Next was a few washes of W&N #2 Burnt Sienna & then # 41 Van Dy ke Brown in White Spirits
Next went a thin layer of flesh-base made of #45 Zinc White , #44 Yellow Ocre, & #2 Burnt Sienna
Even a thin flesh layer makes those hands look less skeletal.
at least that’s who he had in mind(and in his reference picture)–there’s a great tutorial on sculpting a figure based on this one somewhere on
