U-Boat 534 (1/72 ) divided in 5 parts
Good night!!
Here are the 10 pieces for the 5 parts.
Still missing parts but they serve to support the model.
The color rust of some, it is only proof (it is not definitive) and it can be removed at anytime.
All have the corresponding measure for each part and not all are equal.
The next step is very important.
The next step is to cut the model and it will be necessary to study it in detail because after cutting, there is no turning back.
I’m going to study what the cut will do, and I’ll make some diagrams.
At the end of this week I will show you.
Thank you very much!!
Here is the true diagram (found in the U-534 museum) that will help me to cut the model.
Thats a great piece of info Adrian. That will be an immence help when making cuts! If you should choose to thread cut, just take a length of thread, wrap around a piece of stick or something similar, do the same to the other end, then just start pulling back and forth, allowing the friction to cut through the plastic. You’ll fast learn how fast and how much pull preasure to put on it to keep cutting smoothly. As I said befor, it will likely break a number of times, (always does) but it should give you a good clean cut in the end. Good Luck! Can’t wait to see the end results. I’ll be starting mine soon… I hope. Take care!
Doug
Hi Rigidrider!!
Thanks for your words add emotion to the project !! And I like your words very much!!
I will prepare the documentation to show the tool that I will use to cut the submarine-model.
In a few days I will upload the plan or stages that I will follow to cut, and a few days later (I just prepare the documentation) I will show the mechanism that I will use to cut it.
The mechanism is very simple and easy to use but I need to explain it because it has its foundation.
Thanks you very much!!
Adrian
Very cool subject - I will be follwing.
Thanks!!
Very ambitious and unique project Adrian! I’m curious, do you intend to do a cutaway on any of the sections to show some of the interior? I have the type IXC Revell kit with a full interior (resin and pe kits). I’m sure I can learn some tips and techniques watching your wip. Looking forward to it.
Thank you for your words!
Exactly to cutaway some seccion , no, but some seccion show his interior like the part where the machine is (seccion number 3). Oher parts like the front seccion shows us about 25% of his interior.
All the sections show us something of their interior transversally. And it’s going to be another challenge to do.
if you do some of the type IXC Revell kit with a full interior, I wonder to see your work because I will like to study each part.
Here I show you the inside of the front and the machines section to give you an idea.
Here is the general plan of the modifications that must be done
with ‘click’ to enlarge the image and observe more detail
Here are the steps to be able to cut the model
In these following days I will give you ‘how and what will I use to cut the model’ …
One of the challenges is the challenge of how I will represent all the skin of the submarine (which has many holes and prominences) to make it look real (as real as possible) it is very interesting
The general idea is that the cut of 5 parts, need to be fine and delicate as posible but, in this case, the cut does not need to be in these way.
The challenge and the risk to be able to make the skin, is to use a printing sheet that will cover the plastic.
In the printing sheet it is more easy to imitate the alterations of the submarine.
It will be done in the final stage of the whole project and it will be another great challenge because it must remain as real as possible.
It is related to the cut because the plastic will be covered with the printing sheet. obviously the surface has many peculiarities to take care.
let’s see how it Works:
Any question I am at your orders…good!!
