any suggestions for supplier of hollow tubing for different scales for spark plug wires, brake lines, fuel lines, etc.
I got back into car model building after a couple of decades away, and im trying to push my skills.
I recently completed a Pocher 1/8th scale mercedes 540k that was started back in 2000, an amt cord, and working on a 57 tbird and a bugatti royale. I prefer the larger scales due to chubby fingers.
If using tubing, cut the plastic pins off of the kit part that the tubing is supposed to be forced onto. Drill a small hole and glue in a short wire pin. Glue the tubing onto that.
Those kit plastic pins are tapered and cant hold the tubing for long.
I saw something recently about hollow fishing line (I assume for fly fishing). Some of the options at Teds Modeling marketplace - https://www.tedsmodelingmarketplace.com/
What material- brass, aluminum, stryene? Most popular brand of metal is K & S, found at most hobby shops, some hardware stores, and online. You have two choices of stryene, Evergreen and Plastruct. Some hobby shops carry both, most carry at least one, and both are on the web.
If you are talking about as you indicated, Spark Plug wires etc. then I use electrical wire I buy by the foot at Home Depot. In the larger scales you can pull back the insulation a bit, Cut off the wire inside and it will leave you a opened end. Put that on a pre-installed brass rod pin and you are good to go.
When I worked exclusively in 1/8 and 1/16 I used the same type of wire, just different sizes and larger wire insulation, for short nubs for Spark Plug Boots. If you use the finer wire as is, with the opening on the end, the wire left inside will keep you from getting a crushed curve. Just don’t try to make those curves too tight!
If it’s absolutely impossible to get that, then use soft brass wire and a Micro-Mark Tubing/Wire bender! Using Solder is good too.My landlady does Stained Glass Crafts and I am always raiding her stash of solder for detailing my Planes.
I need some stranded electrical wire for my Mephistophole. Supplied wire is green! Photos show black and I have never had good luck painting vinyl. I need about 28 insulated, but finest I could find locally was 18 guage
Guess I’ll have to order it, but I am ready for plug wiring NOW.
Scrounge up some old computer/electronic cables, and strip the wires from them as they come in all sizes and colors. For tubing needs, just strip the insulation from the wires and use that.
I have been hunting the same stuff for the last couple of years. Prime Minitures, a nice guy in England has great silicone tubing in several sizes. Clear and Black. It is is very soft and supple and bends nicely with out kinking. I have also found that silicone insulated wire is a perfect fix also. I have it down to 30 or 32 gauge. Amazon is the place. If you search silicone insulated wire you will fone a vast array of suppliers and colors. I found sellers that sell it in small amounts and the prices are very good. I use red and black. I also bought a mininture wire stripper from Amazon. This way you can use the wire as is, or I on occasion strip the sinulation off and use as tubing. I use the very small gauge as wiring on 1/20 motors, works great.
MFH has a line if very small silicone tubing also. Some less than 1 mm. Perfect fuel lines, brake lines, what ever. I use their clear brown as fuel lines on 1/20 motors. The MFH stuff is not cheap, but it is good. A bit hard to come buy right now.
if course Detail Master has all the fancy metal pieces. A vast array of AN fittings. Very nice stuff, again not cheap.
I would for sure try to get the silicone wire, easy to get, budget wise and may options in size and color.
Go to Amazon and search silicone insulated wire. you can get all the way down to 32 ga. I use all kinds of this stuff on 1/20 and 1/12 cars. I just used a bunch on the 1/12 Italeari Alpha 8C. it is soft, supple and easy to use and bend.
You can get lentghs in the 15’ area and some comes in colors. I use red and black. If you get a stripper, goes to 30 or 32 you can pull the insulation off the carrier wire and use it like tubing. It is handy and not all that expensive. if you buy the fancy small tubing from the model outfits it is bloody pricey. Amazon not so much.
It’s a synonym for the devil. So named for the devilish noise it made. It is a racing car, a land speed record car. I’m detailing the build in this forum.
I will check out the wire on Amazon as soon as I leave the forums, Phil.
