TRUMPETER'S 1-350 HMS HOOD WIP
I started this Build a little while so I thought I would share my Build with you. The Hull and Main Decks are together. The Main Deck is not glued completely as I am doing it in sections. My 1-350 Hasegawa Yukikaze is in the background to give her size some perspective…
Main Hull Colours have been added and prelimanry Superstructure Work has been started…
After 4 Hours of masking and 5 Minutes of work with the Airbrush, all moulded on Deck Fittings are now done. Moulded on Anchor Chain has been sanded off and Hawes Pipe and Chain Locker Openings have been drilled out to accept some Aftermarket Chain…
Main Deck Bulkheads have now been added and to say the fit was ordinary is being kind. The Fit is woeful. Lots of filling and sanding to be done to get them to look presentable…
After a lot of Sanding and Painting, I am now able to mount her on her Stand to continue her build…
A Note for anyone who is wishing to Build this Kit using Photo-Etch, The Area on the Boat-Deck, that is circled in the Instructions, is actually a Hatchway with a Canvas Cover. Trumpeter have Moulded it to the Deck as you see in the following Instructions…
I removed that part of the Deck and sanded it to shape to accept P/E Hatch Coaming and surrounding Stand that the Canvas Cover was attached to…
Finally, I placed the Boat-Deck on to check it’s fit before continuing…
More prgress Photos and info to come. Any comments and Friendly Criticism is most welcome…Cheers Mark
Lookin good so far.
Wow, 4 hrs of masking. Whew. She’s coming around though.
Thanks for the comments Gentleman. 4 Hours of masking may seem like a lot of time but it saves on going back to do Touchups. More Photos to come soon…Cheers Mark
Sure admire the attention to detail, but don’t you think that at that scale someone could use a good brush and something like a postcard to help with straight lines and simply hand brush it? Not quibbling mind you, just want to understand the approach. I’m beginning to like ships - they don’t have cockpits to mask, landing gear or very many decals.
Eric
Thanks for the comments Eric. You could do it that way if you wish but I decided to try this Method. I have attempted what you have suggest but a very steady Hand is needed. You could mask around each individual Moulded piece of Deck Equipment and paint it that way, but I have always found that there is a slight variance in the finish of Hand Painted to Airbrushed when they are close together. In the end though, each Person has their own way of doing things and if that makes them happy with the outcome they achieve then good for them…Cheers Mark
Hood’s Shelter Deck has now been Painted and is Test Fitted into Position. Rigging Holes have been drilled into the deck to accept the Retaining Straps for the Ship’s Boats. More to come soon…Cheers Mark
Looking good, surf. Might want to cover that beautiful base up.
Thanks for the comments Bondoman. I intend to cover the Base before I start any more major work on her…Cheers Mark
excellent progress!
Nate
Thanks Nate. Much appreciated…Cheers Mark
I have’nt been able to do much lately because of that dirty 4 letter word called W.O.R.K. Have started adding the Ship’s Boats to her Boat Deck. I Have not glued the Boatdeck down yet as I wish to make it easier to attach her Boat’s retaining Straps. More to come soon…Cheers Mark
Looks like your coming along nicely.
Thanks for your comments. Much appreciated…Cheers Mark
imho hms hood was the most gracefull looking ships to ever sail :slight_smile:
your doing alot better job than i did of mine mate keep it up :slight_smile:
Thanks for the comments. They are much appreciated. When I have done some more work on her, I will post some more Shots…Cheers Mark
coming along nicely and a beautiful base… look forward to the rest!
Thanks muchly for your comments. Am still working on the Ship’s Boats but have also started work on the main 15 Inch Turrets. Will have more Shots up shortly…Cheers Mark
