Trumpeter 1:350 HMS Dreadnought 1907
I am just starting this beast and already have aftermarket wooden deck and other Eduard PE to come.
My question today is about these “holes” in the upper hull, all the way around. I think they might be ports and thus would they be best drilled out? I know the one that I circled is actually for the net booms.
Those holes/depressions are Port Holes. Most of us drill’em out.
Option to to use some Tempra-type paint to fill the holes- them wipe off excess on hull works too. The port holes really stand out with gloss black.
Another option… I have tried drilling the port holes in another model , painting the hull, then using Testors Crystal Clear in each port hole to simulate glass, and then adding the deck. However, I found this to be awkward as I feared, with good reason, scratching or marring the painting on the hull while getting the deck glued in place. I just drill now.
Glad you spotted the locations for the Torpedo net booms
You can make your own Torpedo net to be rolled up against the hull. I read of one modeler using thin black shoe lace.
To show the net extended there is some PE out there to show it hung in place but it is sized for a water-line display.
I have not built the Dreadnought but I am interested in getting the Trumpeter kit as I consider it better than the Zvezda version.
Thanks for starting this thread. Sign me up for the duration.
Nino
Nino - thanks for the help. Yes, I want to drill them out as I am pulling out all the stops with this kit and the add-ons. Still waiting for 2 sheets of Eduard PE.
As to the ports, I too had thought to use Micro Kristal Klear and will try that from the inside before I close the deck. If not, I will try some of the left-over plastic sheets I have from some HO windows, again from the inside.
I also saw mention of grills for the chain lockers so I am using some old screens from a tank project, again from the inside.
As to the torpedo nets, I will wait to see what the PE sheets have.
I will post more as I receive them, thanks for the interest. [:)]
I’ll be following you on this. I got the kit last year with the deck and other goodies. I also agree that the Trumpeter kit is the best after some research before I invested in all that plastic, metal and wood.
There is an article from 2017 (I believe) in FSM that will be a great tutorial in the construction, and was the inspiration for me to get it. Always been one of my favorite ships.
Chris - I have that October 2015 tutorial and am using some of those ideas, such as adding grills to the hawsepipes, from below.
I am also going to add some ribs (maybe not 16), as I see them in some of the photos I searched.
Also, I have drilled out all the many ports and filled from behind with Krystal Clear. Think it looks OK on this super deck.
Pictures to follow after I sort out my Photobucket account. Do not want to pay $6.29 for upgrade. What are others using?
Well, here are the 2 pictures but don’t think I will be able to continue with Photobucket as they say I am using 20.5 of 25MB band-width. Don’t know what it means but seems like Photobucket may not be the way to go now?? [:^)]
Another question for someone more astute than me. I bought the Wood Hunter deck and also got some PE. I understand most all but 2 and 3 have me perplexed as to where to put them.
And frankly, I am also having some trouble figuring out where some of the Trumpeter sub-assemblies are supposed to be used once built.
HELP??// [:P]
Wouldn’t you know that Photobucket obliterated the detail I wanted to show. Any other options would be most appreciated!!
Those holes are to mount the booms for the torpedo nets.
Mark
Thanks Marcus - I have drilled and filled the ports and have rigged the poles in the proper holes that I circled.
Hi;
When I drill out ports , I always use .020 clear sheet inside painted black on the inside. I seems to work well in all scales.I learned this from the stuff I do with trains .
Hi Tankbuilder - yes, I have done that with my HO RR projects and considered it but there were so many and so tiny that I decided the Krystal Klear would be effective.
Thanks for the tip.
Those are hose reels. #2 is how it looks on the tree and #3 is what it should look after bending. I use a piece of small round sprue, usualy from Evergreen, to use as the center of the reel. I will sometimes also wind some small gage fishing line around the sprue to simulate the hose.
My 1/350 Prince of Wales…still in progress [:$]
BTW, for photo hosting I use Imageshack, no adds and no watermark but that just me. Others use other hosting sites and avoid Photobucket like the plague
Steve - thanks so much for the help with the reels. I kind of figured that is what they might be but am not sure where they are going to fit on the Dreadnought, but I will use your example as a start.
Thanks also for the help with the miserable Photobucket. I will give Imageshack a look.
[:D[
Thanks Jake, you should just be able to shave off, or leave off, the kits reels and install the PE ones. It doesnt look like there are any instructions for placement so that’s what I’d do.
So far, I have not been able to ID any kit reels so we shall see. BTW, your Price of Wales looks outstanding.
Thank you Jake
photoimage.org is the one I use, because photobucket was such a chore to use, and I could not get it to work right. When using photoimage.org, I use the direct link under share, and here I use 600x400 in the size box. Hope that helps.
Thanks so much for the help. I now have 2 sites to explore and can sh…can Photobucket.
