So, after 4 days of no 'net (thanks at&t) and having to get logged back in, I can give 2¢ on this.
What I find effective is to get your mounting system installed. Unless I have a compelling reason not to (which is an essay unto itself) a pair of fasteners at 1/3 back from the bow, and a 1/3 ahead of the stern. Then set a bugle-headed machine bolt with washer into some epoxy through the bottom of the hull. I have found using bolts that are 3-5x the hull depth to be ideal. This can be snubbed up with a nut on the outside (put a dab of oil on the nut to keep the epoxy from gluing it on).
Let that set up good and strong.
Now, find some scrap lumber. In perfect world, that lumber would be a bit longer than the overall length of the hull, and the same width wide. Take another bit that same width and securly fasten it at one end or the other of the bas board so it makes an “L.”
Drill you base board to match your hull bolts. You want to sand the hull off the base board by some distance, that distanct can be set with brass or plastic tubing (I’ve used PVC) that you pinch between the board and the hull by using washers and nuts on the bottom of the board.
Now, that “L” leg can come in handy as you can lay the hull and board on its side.
Now, you go to your refernce materials. You will want a copy of those you can mark on. Lay out where your board aligns to the hull. I will then fuss the fit of the board with shims and washers until I can get the mounting base parallel to the waterline given in the reference. Adjust your baseboard refence line accordingly.
If your reference plan is not 1:1 to the model, I will put the conversions factor in bold ink somewhere handy. Measure the actual distances on the reference as accurately as possible (top of boot, bottom of boot, LWL, etc.) and label them on the reference. Now convert those to actual measurements on the model one at a time. (If your plans are 1:1, you can just use dividers.)
Ok, all that sorted, you just need to stand the hull on its base on a nice flat surface. Take your scribing tool–whatever that is–and shim/block it to the correct distance you need, and scribe in the line(s) you need on the hull.
Note that boot topping is fixed horizontally, not fixed in width, so in inverse plan view the boot top might be very wide.
So, yes, a ton of work. But, having that base gives you a lot of control on the hull. You can put it in an adjustable vise to leave your hands free. You can mash the vise down hard and not risk paint or details.
When you get to the finished base, you can decide on how to mount the things–tbes, blocks, finials, and those can be fit to the base and the hull. The embeded bolts give you the purchase to hold it down. Cut the bolts to fit the finished base and you’re all set.
