Troubles with "Tante Ju"
I have run into a problem with the assembly of a 1/72 Ju-52 and I know this is THE place to come for help! [bow]
The problem I am having is when the seams are in the corrugated areas. I guess I should have thought of all that prior to starting the kit, but where’s the fun in that, right?! [sigh]
Is there an easy way to deal with this “problem,” or will I just have to “pay my dues” and deal with the detailed sanding, filing, and restoring the corrugated areas. I know that I can protect surrounding areas from “collateral damage,” but there will inevitably be some.
Any suggestions would be appreciated!
Rich
Oh man, that corrugated siding is going to be fun to work with! [:O]
I’m not familar with the kit, and don’t know where the seams are located on it but it sounds to me like a nice small set of needle files, some sand paper that can be folded so as to be able run it along corrugated dips, and some very gentle scraping with a sharp x-acto knife would do the trick. No matter how you go about it, it’s going to be a time consuming, attention to detail type process. Just take it one bite at a time. [BG]
Good luck with that, and I wouldn’t mind seeing some pics of some of the seams you’ll have to work with.
Well this might sound ridiculous, but have you considered supergluing 4 or five x actoblades together side by side holding them in a small clamp maybe and dragging them across the surface? I think it might give you the clearance between points to treat the corrugations. Just spitballing here…
Another idea is to cut a V shaped wedge from a small piece of wood and cover it with a very fine cut of wet 'n dry sanding paper. Sanding between groves might save the details if you are careful and patient.
Or a V shaped needle file will do the same job if you have one.
Whichever way you do it, you will need to take your time. I hope this helps,
