I am having trouble creating the “right” effect with my homemade tarps, and I would like to present some questions:
I am looking to create a tarp over the turret opening on an M10 and a few bed rolls.
I have read some How to’s on the subject and all seem to say “soak” the tissue with 50/50 water and elmers, My problem is I cannot seem to find the fine line between soaked and not enough. It always seems to either remain looking like a used kleenex and a torn mess. How many tissues do you use for each? Should you layer them? Is there a better brand? Is “tissue paper” better than Kleenex type?
When during the process do you mold the tissue into what you want? Should you wait until it dries a little and is more plyable or place it on right away?
Yes, you want the tissue paper that you wrap shirts in. The kind you have to push out of the way in the gift box to get the shirt out. It comes in all sorts of colors, but mostly you see it in white which suits our purpose perfectly.
To be honest, I’ve never bought any. I’ve been “collecting” it after each Christmas for quite awhile.
I’d try to go to any store (like department stores) that will “wrap” your gift for you and see if you can get a couple of extra sheets.
If the free route fails, try Walmart or some other store which sells gift wrapping supplies. They should have it.
Tissue paper is the way to go. Craft stores like Michael’s et al. have plenty. I mentioned before in another thread that I like the feel and thickness of paper coffee filters as well. A little bit thicker and more durable, but treatable with the same techniques!
Actually … I use tissue paper … the kind you would blow your nose in.
For an opening like the turret of the M10, you would need some support for the tissue to work well. The nice thing is that when the real M10 was tarped down it had a framework to support the canvas. Build your framework out of plastic or metal rod or even solder will work. Cut you tissue a little larger than the actual opening and set iin place. Apply your mixture of glue and water with an old paint brush. Form the edges to your tastes and trim is necessary. Allow to dry then paint and weather.
latch66,
Thanks for the explanation. I thought that was what you were referring to. I think I’m in trouble, nobody gives me any gifts (sniff, sniff).
Robert,
Do you have any “expert” tricks you use? Do you always form and place the tissue and add the water/glue mix with a brush? Does the painting come after the piece is placed, formed and dried?
By the way, really miss the “I want you to build a Sherman” poster, it was a classic.
Regards,
Joe
Joe - No expert tips on this one. It just takes a litle bit of practice, and not really too much of that. I always place the tissue before adding the brew to it, then form or trim the edges after it is wet. Painting and weathering comes after it is all dried.
Kind of miss the Uncle Shermie poster too … save it for the next build maybe.
Hey Robert,
A little practice usually works if you have some talent, in my case it will probably be quite a bit of practice. Thanks for the advice and I’m looking forward to the return of “Uncle Robbie”.
Regards,
Joe
