I am having a problem with the rear engine grill. It seems to be too big. If I position it to fit properly in the upper hull, then if hangs over the tops of the rear lights. If I position it on the lower half, then it sticks up above the top of the upper half. If I try to force it into the correct position on both halves, then the two halves are not flush with each other.
Have others run into this and is there a solution without whittling this grill into the correct size?
