This aircraft is a low wing monoplane first manufactured shortly before World War II. It was designed to be a safe fixed-wing aircraft and the type still enjoys a very faithful following today. Designers strove to create a reasonably priced aircraft that would not stall or spin. It included a fully cowled engine, tricycle gear (for ease of maneuvering on the ground) and a tractor propeller configuration. This aircraft first flew in 1937 and saw some militray use during WWII. It sold at a cost of $2,665 dollars in 1946. It was produced by several different companies during it’s life and is the only extant tricycle aircraft that meets a certain FAA definition.
Name this aircraft. Answer by PM only. Do not answer " Was It " or with a question mark. No changing of an answer after your original submission. Any answer submitted after 1200 hrs E.S.T on the day the answer will post will not count. Answer will post on 03/30/07 at 1200 hrs E.S.T.
Brian [C):-)]
