This aircraft was of a type used to test tailless designs. In the late 30’s Armies were looking for a way to airlift heavy military units. At that time their were no cargo aircraft big enough to lift a tank, and even if such a large aircraft had been created it would have needed many special facilities. A possible solution explored was to add wings to a specific piece of equpiment, but most aircraft designs were based on straight wings with extended empennage and stabilizers. A design by one engineer was for a 100 ft wingspan aircraft consisting chiefly of a swept wing with vertical stabilizers on the wingtips. The prototype aircraft that made the first flight was built entirely of wood. Tests were sucessful, but the project was abandoned since a decision had been made to develop a specific type of aircraft which could carry heavy equipment within their fuselages. The one prototype aircraft built was a tailless flapped monoplane to be available for research to test the stability and control of tailless aircraft.
Name this aircraft. Answer by PM only. Do not answer " Was It " or with a question mark. No changing of an answer after your original submission. Any answer submitted after 1200 hrs E.S.T on the day the answer will post will not count. Answer will post on 03/19/07 at 1200 hrs E.S.T.
Brian [C):-)]
