MOAENB TONNNB03ANPABLLINKA AT3-22
also can you recomend a translate program in free were
thanks
jd
thanks
jd
That all in Cyrillic? IM Translator can’t read it…
Я может ниуать Русский языкю (I can speak Russian)
If you can not type in Cyrillic than I can not transtale it though. If you scan the document and post it I can translate it. Or if you can write it down and scan it I can also translate it. The translater will not do you any good either if you can not type Cyrillic.
Soulcrusher[oX)]
Click on START, select all programs, then accessories, then system tools, and then click character map. A window will open. Scroll down a little bit. After the Greek alphabet you will find the basic Russian alphabet. The first few letters look like this
АБВГД
Click on the first letter then on select. Repeat with each letter. When you have selected them all click on copy. Now you can paste all the letters into a document with Control V and save it. Now you can use copy and paste to build up the words you want and then copy the words to where ever you want. Provided the font used includes all the characters you will have no problems using this method.
/Phonetic “Ya spishu Ruskyi yazik” /phonetic.
It’s been a while for me, though.
It says, ‘Lufty is ace, all bow before him’. Thx for posting [:D]
…Guy
Thaks all fpr the help will try when bacb from store]
jd
Sorry to inform you Guy but in reality it does not say anything that I can understand because it is using english charectors not Cyrillic so it really does not say anything.
The good news is you are “ace”[tup] but as far as I know you are not royalty so there will be no bowing on my part at least.[:D]
Cidadelgrad I read and write it much better than I speak it. I spend about a year translating and responding in Russian and the basics have always stuck with me. Once you get past the alphabet it is no harder to learn than any other languages. мой друг.
Soulcrusher[oX)]
