Track sag correction (maybe)
Friction shouldn’t be a problem because it is an actual roller, there’s a smaller tube (shaft) inside the one you see. After painting I may squirt some molylube in there to grease it.
In terms of construction, the shaft goes through the hull so it’s pretty sturdy.
I only did this to one side so far to see how it works. There is no drift when driving it, so I assume there is no drag or strain on the motors.
Great points, Thanks.
I agree with J-hulk. Paint it black and see if you can see it. It is hardly noticeable in that first shot. If you weren’t so good at close up photography we wouldn’t even know it was there.
