Hey guys,
I figured out a new trick tonight. Does your touch-n-flo applicator ever get clogged from the inside? I don’t mean the tip, I mean the little pieces of crap that get down inside the tube and clog it? Well, I figured out a fast way to clean it.
I took a throw away plastic dropper and stretched the tip like we used to do in chem lab. Then I sucked a little rubbing alcohol up in it, put the skinny tip in the back end of the touch and flow, squirted it out, then sucks it back in with the pipette. The whole process took about 5 seconds and now it is as good as new.
Just make sure there isn’t still tenex in the thing when you clean it…
~ Garth
