I wanted to light the model. I wasn’t sure what I was going to do, it is rather small. To do the lighting, I decided to do a Raython Lighting effect with the top windows. To acomplish this I primed the model with black primer as a light blocking layer. I believe I did 2 coats and then tested that it was properly blocked. Once I did that I painted on the base color I was using for the hull. Once that was properly dried, I used a pin vice drill to drill into the paint and primer on the hull.
The Plasma Torpedo launcher was simply drilled out, and the back painted with a few coats of black paint. The LED is a filed/sanded down 3mm LED to fit the tight space.
The interior light is a basic LED Strip. The lower hull was light blocked on the inside, except along the “front window” area. The outside of the hull was light blocked similar to the top. I didn’t do anything on the front windows in the end.
The Nacelles has a little work done using some copper tape to get power to them. The LEDs are 3mm LEDs. The wires for the LEDs are soldered to the copper tape.
After I finished assembly, I did have to fix some light leaks in a few areas. Then the model received another coat of the base paint color to work on blending that out. Then a light coat of Future to clear and prep for the Decals. The Nacelle Domes received a clear matte paint on the inside to break up the light a bit.
The Decals almost worked well. There are bubbles under the bird wings.
The seams could have been done better. This model was done to be a simple model. It was also a bit of practice. I did glue the wings to try to close those up a bit. I didn’t do any putty work. I’d like to see a larger scale model of this, and then I would do more with the lighting and go for a more finished result.
The color choices were mine, I know the Plasma wasn’t Green. The ship may have been silver. They say the Nacelle tips should be chrome, which I did use Vallejo Acrylic Chrome, which worked out better than I expected even though it isn’t a real polished chrome look. For me it is less about what the Studio Model looks/looked like in person and how I it looked on TV to me as a kid.
It is just static lighting, I did run wiring to different groups of the LEDs incase I wanted to do something different at some point. There just isn’t much to work with there. The wires are wrapped around the support rod and painted black. They go to a simple Micro USB connector under the base that is insulated with some heatshrink. I expect to secure that port to the under side of the base in the future.
