Tiger Modifications
For our Tiger lovers everywhere, courtesy of Mr. Jentz and Mr. Byrden:
Tiger I Modifications List
(copyright Thomas L. Jentz 2001)
Modification
Intro Date
Described in Reference 1 Text Section
Shown on Drawing* in Reference 1
Reference Book Accurately Showing Each Modification
Ref.1
Ref.2
Ref.3
Ref.4
Bent narrow front track guard
May42
3.4.1.3
Pg86-88
X
X
Drive sprocket ring alignment
Aug42
3.4.1.6
Pg86-88
X
X
Jul42 tools w/5 cleaning rods
Aug42
3.4.1.4
Vent slit in engine hatch
Aug42
3.4.1.7
Hooks to hold rear louvers open
Aug42
3.4.1.7
Pg86-88
X
X
Hinged flapper on exhaust
Aug42
3.4.1.5
Pg86-88
X
X
Pz.III baggage bin (middle)
Aug42
3.4.2.3
Pg86-88
X
X
Holes to mount camouflage frame
Aug42
3.4.1.8
Pg86-88
X
X
Smoke candle dischargers
Aug42
3.4.2.1
Pg86-88
X
X
Track cable on hull side
Sep42
3.4.1.4
Pg86-88
X
X
Two hinged toggle bolts
Sep42
3.4.1.5
Pg86-88
X
X
Tarp tabs
Sep42
3.4.1.4
Pg86-88
X
X
Full tool set
Sep42
3.4.1.4
Pg86-88
X
X
Delete antenna base on rear
Oct42
3.4.1.10
Pg86-88
X
X
Brackets “Feifel” air filters
Oct42
3.4.1.11
Pg86-88
X
X
Cylindrical convoy tail light
Oct42
3.4.1.4
Pg86-88
X
X
Tow cables reversed
Oct42
3.4.1.4
Pg100-102
X
X
Shovel on glacis
Oct42
3.4.1.4
Pg100-102
X
Mounted “Feifel” air filters
Nov42
3.4.1.11
Pg100-102
X
Track guards on sides
Nov42
3.4.1.3
X
X
Pins on cupola for rain shield
Nov42
3.4.2.5
Pg100-102
X
X
Single piece side track guards
Nov42
3.4.1.3
Pg100-102
X
X
Hinged track guard front & rear
Nov42
3.4.1.3
Pg100-102
X
X
Reinforced gun mantle
Nov42
3.4.2.7
Pg120-122
X
X
Crew compartment heater
Dec42
3.4.1.9
X
Emergency escape hatch
Dec42
3.4.2.8
Pg100-102
X
X
Track tool stowage box
Dec42
3.4.1.4
Pg100-102
X
Hull side at front not notched
Dec42
3.4.1.4
X
Last Pz.III stowage bin (high)
Dec42
3.4.2.3
Extended hull side at front
Dec42
3.4.1.4
Pg100-102
X
X
Starter plate mounted vertical
Dec42
3.4.1.4
Pg100-102
X
X
Straight side track guards
Dec42
3.4.1.3
Pg100-102
X
X
Mounts for S-Minen dischargers
Dec42
3.4.2.11
Pg100-102
X
Cables and antenna stowage moved
Dec42
3.4.1.4
Pg100-102
X
S-Minen dischargers
Jan43
3.4.2.11
Pg120-122
X
Exhaust muffler guard
Jan43
3.4.1.14
Pg100-102
X
X
Triangle ends on side track guards
Jan43
3.4.1.3
Pg100-102
X
X
Gun mantle cut for Tiger P
Jan43
3.4.2.7
Pg100-102
X
Tiger baggage bin
Jan43
3.4.2.3
Pg100-102
X
X
6 cleaning rods
Feb43
3.4.1.4
Pg100-102
X
X
Starter shaft on lower hull rear
Feb43
3.4.1.4
Pg100-102
X
X
Engine compartment vent cover
Feb43
3.4.1.7
Pg100-102
X
18 bolts holding roadwheel rim
Feb43
3.4.1.15
Pg100-102
Stop K.F.F.2
Feb43
3.4.1.16
Pg100-102
X
X
Ring retainer for track pins
Mar43
3.4.1.12
Modified “Feifel” air filters
Mar43
3.4.1.11
Pg120-122
X
Triangle cover on rear deck
Mar43
3.4.1.7
Pg120-122
X
X
Loader’s periscope
Mar43
3.4.2.15
Pg120-122
X
X
3 spare track holders
Apr43
3.4.2.16
Same casting for rear louvers
Apr43
3.4.1.7
Pg120-122
X
X
12 bolts holding roadwheel rim
Apr43
3.4.1.15
Drive sprocket hub
Apr43
3.4.1.6
Pg120-122
X
X
Flippy on engine hatch sides
Apr43
3.4.1.7
Pg162-164
X
X
2 spare track holders
Apr43
3.4.2.16
Pg120-122
X
X
Maybach HL230
May43
3.4.1.18
Pg120-122
X
X
X
Drop frames rear track guard
May43
3.4.1.3
Pg120-122
X
X
Drop smoke candle dischargers
Jun43
3.4.2.1
Pg134-135
X
X
Shock absorber mounting
Jun43
3.4.1.19
Pg134-135
X
Drop two hinged toggle bolts
Jun43
3.4.1.5
Pg134-135
X
X
New turret w/cast dupola
Jul43
3.4.2.20
Pg134-135
X
X
Pistol port plug & uncut escape
Jul43
3.4.2.20
Pg134-135
X
Zimmerit
Aug43
App.F
Forged cap on combustion air intake
Aug43
3.4.1.7
Pg134-135
X
X
Stop Tiger P gun mantle
Aug43
Pg134-135
X
X
New holders for track cable
Aug43
3.4.1.4
Pg134-135
X
X
Single headlight
Aug43
3.4.1.21
Wider slit in turret vision ports
Aug43
3.4.2.20
Pg134-135
X
X
Tab on glacis to secure MG plug
Aug43
3.4.1.4
Pg134-135
X
X
Stop submerged fording
Sep43
3.4.1.5
Pg134-135
X
X
Add C-clamps top and rear
Sep43
3.4.1.4
Pg140-141
X
X
Chevrons on track
Oct43
3.4.1.12
Pg134-135
X
X
Headlight centered
Oct43
3.4.1.21
Pg134-135
X
X
Stop S-Minen dischargers
Oct43
3.4.2.11
Pg134-135
X
X
Drop loader’s hatch lock disc
Oct43
3.4.2.20
Pg134-135
X
X
Hand crank by antenna base
Oct43
3.4.1.4
Pg134-135
X
Stop pistol port plug
Oct43
3.4.2.20
Pg140-141
X
X
Stop track tool stowage box
Oct43
3.4.1.4
Pg140-141
X
X
Stop “Feifel” filters
Oct43
3.4.1.11
Pg140-141
X
X
External travel lock
Nov43
3.4.2.21
Pg140-141
X
Stop mounts for “Feifel” filters
wow
Poison-gas detection? That’s a new one. Thanks for taking the time in compiling this list.
Late Tigers and Panthers had provision for mounted panels that changed colors if poison gas was detected.
This list originally appeared in Jentz’ book “DW to Tiger I” and is also part of this article:
http://missing-lynx.com/panzer_facts/pftiger.htm
