Tiger I, Steel rimm wheels
This sentence comes from Aromorsite http://www.fprado.com/armorsite/main.html
…“In February 1944, steel road wheels with internal rubber cushioning, adopted from the Tiger II, were mounted in the Tiger I. These were chosen because of their ability to bear the weight of heavy armored vehicles…”
Internal rubber cushioning” how does that work?
Looking forward to Your input on this!
Svenne
There is a cut-away view of a all-steel road wheel on page 143 of Spielberger’s Panther & It’s Variants. It’s a bit difficult to explain without a drawing, but basically the outer steel rim of the wheel is sandwiched between two rubber rings contained inside the body of the wheel.
So it’s sort of like a rubber o ring in between to metal rings?
Heater
Here is the drawing of a cross-sectional view of a steel wheel;
The Gummiringe are the rubber rings, sandwiching the rib of the inside of the outer steel rim, the Stahllaufring.
Great Stuff! Thank You very much Kykeon [:D]
Regards
Svenne
