It’s been raining here the last 2 days (kinda wierd for July), so there is a bit of moisture in the air. I was spraying last night with my Iwata BCS when I noticed moisture coming out of the tip - I spray enamels so it was not much of a problem.
Now my compressor has a moisture trap on it and I am perplexed as to why moisture was building up in the AB head.
I switched back to my paasche VL and no moisture appeared to come out the nozzle
I don’t even have an airbrush but I myself have had weird things happen to enamel paint when I tried to use it on a rainy day. With the dampness in the air, I think just enough moisture would get in the paint to make it act funny. It doesn’t always happen, but I’ve had it happen enough to where I usually won’t paint on a rainy day. Since I live in a normally dry climate, I rarely have to wait more than a day or two before I can paint.
Just out of curiosity … do you guys shake up your paint or stir it? If you shake it, only the air in the bottle (a negligible amount) will get mixed in the paint, but if you stir it you are mixing outside air and on a rainy day that would contain a lot of moisture. I’m not sure how much, if any, moisture would get mixed in, and I just wonder if that would make any difference.
