thinning Dullcoat
can any body tell me the ratio of thinner to Dullcoat, my bottles of thinner and Dullcoat did not have the mix ratios on them. thanks for the help
Having used Testors Dullcote and Glosscote exclusively for my models, I have had consistantly great results with a ratio of 1:1. I set my compressor at about between 15-20 Psi. When I don’t want to use Future as the Gloss and have to wait for it to cure, I airbrush the Testors Glosscote, mixing it at a ratio of 2:1, with the same compressor setting. This is because I have found that you have to build up the layers a bit. To offset this I simply add an additional eye-droppers full more (2:1) for Glosscote. Works great, and becuase they’re laquers, they dry almost instantly, allowing me to move right along with weathering washes with no problems. Give it a shot!
thanks plasticmod992. the consenciss seems to be a 50/50 mix. i’ve been several other ratios so i’ll try them all and see which one works best. thanks once again.
