Here’s an alternative approach, for fitting link&length tracks, but it only works if you’re confident about, and happy to, paint the tracks and running gear in place, or as one unit.
Build the lower hull. Do not fit the upper hull in place yet. Now build the running gear, and cement it in place, except for the drive sprocket. If you want to paint the tracks and running gear as one piece, but off the model, only dry-fit them in place. Now cement the bottom run of the tracks in place.
There is usually a short length of track, and one or two indy links, going towards the idler. Cement the links to the short length with liquid poly, leave a minute or so, and then install this to the rear of the bottom run, using CA. Cement the top of this section to the bottom of the idler, again using CA.
Now comes a short length of indy links - usually 6 or 7 of them - which go round the idler. Place them together, outer side down, on a length of Tamiya Tape, and cement them together with liquid poly. The Tamiya Tape helps to hold them together i the correct position. Again leave them for a couple of minutes, and then test-fit them around the idler. When you have them as you want them, CA this section in place carefully - you don’t want to get CA on the tape. When the CA has set, remove the tape.
Now construct the top run, using the same methods as those described above. If relevant, create a slight sag (don’t overdo it - a saggy track is a shed track, and it’s something modellers often tend to exaggerate) where appropriate, and if the upper runs permit you to do this. Again, use liquid poly to connect the links to each other, and CA to cement them to the wheels.
Finally, you’ll be left with some indy links to go round the drive sprocket. Cement a length of these, two links short of what the instructions say you’ll need, using the same method as described for the idler, and dry-fit them in place on the drive sprocket. Now dry-fit the drive sprocket in place, and join the bottom of this run to the front end of the bottom run.
A point to remember about the King Tiger (and some other tanks, notably the T-34) is that the track links come in pairs. Make sure you use the right type of track link in the right place.
There will be a gap of one or two links between the top of the drive sprocket and the front of the top run. Use as many of your remaining links as you need to close this gap, using CA to cement them in place, and test-fitting as you go. You may need to file the very last link a little short to get it to fit. This isn’t a problem, since it will usually be covered by a side-skirt, and even if it isn’t, you’d only know it was a problem if you knew to look for it.
Finally, cement or the drive sprocket in place with CA, or dry-fit it if you want to remove the tracks and running gear for painting, and connect the track links top and bottom. I normally use CA for this. If you’re going to paint the tracks and running gear on the model, then job done. If not, wait until everything has dried thoroughly (it doesn;'t need to be overnight, but leaving everything overnight does no harm), carefully remove the tracks and running gear as one unit, and paint them.
You can then re-install the traks and runing gear after you’ve painted the rest of the model, but before, obviously, cementing the side skirts, if any, in place.
This sounds fiddly, but it becomes second nature after you’ve done a few link&length tracks, and I find it simpler, and quicker, than any other method I’ve come across.
Cheers,
Chris.
