Hi,
This is XLNT!
Somone said earlier in this thread that between us we have been arguing this for ages and the discussion has been heated at times.
So thank you for your extensive effort!
Very Best Regards
Johan
Hi,
This is XLNT!
Very Best Regards
Johan
The photos you posted are showing up as “Photo not found.” Would you be able to reupload or post a new link to them? Thanks!
In order of usage. These are the original chipset colours from an original manufacturer but done with modern acrylic paint and matched to the originals 100%. You do have a 3% +/- each way light/dark to play with but quite often natural light will do that for you.
I only see the recent photos linked (due to the photo bucket fiasco), but those Dunkelgelb samples reminds me a lot of the colour chips published in the Tomas Chory book - printed 2000, 2005, and 2016. Same order in appearance (but he has five examples), so it’s interesting how similar the results are.
regards,
Jack
These are samples of modern acrylic paint matched to the original chipset. I have seen Thomas Chory’s book and there are only actually 3 RAL 7028 variants as the first one, Dunkelgelb Nach Muster IS NOT RAL 7028.
The first one came into use on new vehicles in February 1943 and was only used until the end of Operation Citadel, the battle of Kursk. It was never entered into the RAL Register and the colour was changed after feedback from frontline troops, but the name wasn’t changed.
Dunkelgelb Nach Muster translates into Dark Yellow after Pattern/sample.
The first actual Colour that was registered as RAL 7028 was the second colour above. It was changed to the brown that is very similar to the Afrika Korps RAL 8000 and to the final shade which was given a field trial by Tiger II tanks with a RAL 6003 Olive green base coat taking part in Operation Panzerfaust in Budapest.
.jpg)
You can clearly see that in the photo above, the running gear is not painted in RAL 7028, but the much darker RAL 6003 and on the hull itself you can see that the lighter colour, which is RAL 7028 is clearly darker than the previous incarnations.
These colours were put to use on new vehicles from Christmas 1944 and officially sanctioned in January 1945.
As an owner of original vehicles I do spend lots of time in archives and also with companies that provide me with support and also equipment etc to keep these vehicles in an operational state. Getting the paint right is just one part of it and being able to work with a company that did make the original paint and will still do it for me (to modern standards) is a real boon.
Using the original colours on my currently operating vehicles I was able, last year to hine a Jagdpanther with it’s long barreled 88 in a hedge at a re-enactment weekend and with extra camouflage such as a net, bushes tree branches etc may visitors actually walked past the vehicle not realising it was there untill we started it up and crashed through onto the battle area, coming to a stop and then firing the 88mm with a blank and setting off all the car alarms within a mile!
What you have to consider, when you are painting german armour is that the colours used from the change from dark grey are mimetic and the shade will change with the change in light and also the hue will change depending on the base colour. Also our own eyes and subconcious will change the colour too depending on background and distance to try and increase detail.
This picture is my 1/16 Trumpeter Jagdtiger painted in the colours above.
The same photo with a black and white period filter applied to that.
Urban background
The dunkelgelb looks a little different as the camera firmware is doing what our eyes and subconcious brain does to try and make out detail and definition. There is still the greenish tinge but it looks more of a dark beige and not as the colour suggests, Dark Yellow!
Here is my complete set
At a pinch, Vallejo’s Afrika Korps Model Air paints will be fine as a RAL 7028 replacement as they are quite close and once mixed with the Green and chocolate brown and there is evidence to support vehicles beint pained with those base shades and used on the western and eastern front.
AK’s real colours are not real! check out my post on that.
Snapdragon,
Well done, sir. As an historian and lawyer there is nothing I appreciate more than good research. Knowing what to look for and how to find it is an art, and one that you’ve obviously mastered. Very cool stuff!
Secondly, Tamiya XF-88 (Dark Yellow 2) appears to be a very close match to figures 1 and 4, assuming that my phone is correctly displaying the colors.
Colour display on phones etc is always the issue with online arguments on forums.
I have sent chipsets to Vallejo and they are meant to be working on a set but when we will see it I have no idea!
in the meantime as a stopgap I use either the modern stuff, but it is really formulated for my big spray guns in the paint shop and doesn’t like airbrushed very well or Vallejo’s Afrika Korps colours that are the closest to the above and Vallejo’s own RAL 7028 which is so close to the DNM colour you can only tell in very bright natural light the difference.
Tamiya and my airbrush don’t like each other and if I do use those paints it is only for paintbrush use!
Many thanks for your awesome work! Tracking down the original paint manufacturer is one hell of a job. This will finally settle the issue on dunkelgelb paint. The story behind your research is fantastic and you should probably write an article on it. Modellers and historians alike will love it!
Thank you for the tip…Vallejo Model Air ral 7027 is a pretty good match for the first registered ral 7028 Dunkelgelb. I’ve confirmed this through coating a few spare King Tiger fender sections and Jagd IV shurtzen.
Fascinating! So for curiosity sake how long has RAL existed?
Josh
‘RAL’ is the abbreviation of ‘Reichs-Ausschuß für Lieferbedingungen und Gütesicherung’. This name can be translated in English as ‘National Commission for Delivery Terms and Quality Assurance’.
In 1927 the German RAL organization invented a collection of 40 colors. Prior to that date manufacturers and customers had to exchange color samples to describe a tint, whereas from then on they would rely on numbers.
in 1953 The RAL colour catalogue underwent changes as part of the removal of the National Socialist regime and the colours that went into the catalogue between 1933 and 1945 were either altered in shade or removed completley.
If you look at the modeln classic RAL list:
You will see that RAL 6003 is different from the wartime shade, RAL 7028 is nowhere to be found at all, and the shades 7025, 27,28 & 29 are consicuous by their absence. They were shades used by the National Socialist Party.
The brown colours, 8012, 8017 strangley remain practically unchanged except they may be just slightly lighter than the originals. It is very hard to tell without a computer light measuring system.
However, in the modern RAL list RAL 1001 which was used for tank interiors IS NOT the colour that was originally used. It is a totally different colour and the closest one is now RAL 1013 or 9001. RAL 1013 is closer to the interior colour that was introduced in mid 1944 after an all over interior RAL 8012 caused a huge complaint and nearly a mutiny from the soldiers. 9002 was also used as an interior colour and is the colour seen on the E-boats, often referred to as E-Boat White. This, believe it or not, has not changed from the original shade and is the only colour used not to have been altered.
Afrika Korps colours survive in the main catalogue but are just very slighly lighter. Our eyes etc won’t notice this and thye just look like the originals, but it is the loss of RAL 7028 which affects modellers the most as the companies who supply us just don’t understand that apart from Dunkelgelb Nach Muster which is NOT a RAL colour and never was, despite the name, RAL 7028 Dunkelgelb was never yellow at all, it was a brown/tan hybrid that changed through the war and there was a toloerence of +/- 3% shade from some suppliers to +/-10% from other suppliers.
original vehicle owners and restorers have this cracked and there are a few paint suppliers which will sell RAL 7028 in it’s various shades from recipes obtained from OEM suppliers that have gone out of business or been folded/bought by other companies.
My OEM supplier is still in existance and supplies the modern German Army with paint and myself with Original chipset accurate paint by a private agreement. it comes from their archives and I can choose any of the RAL 7028 chipset and batch variants in 500L quantities. I have about 20 different shades to go at!!!
When Vallejo finally get around to releasing the paints then you will have the original chipset accurate colour to play with and you can then darken or lighten it to a tolerence of +/- 10%.
Of course, when photographing your builds outside, the light will do this for you anyway! I always use natural light for “scale effect” as the german paints were to a certain degree, mimetic and to our eyes would be darker on overcast days and lighter on bright clear days.
YOu all need to email or message Vallejo and ask them when the RAL 7028 shade will be released!
Thank you for the history lesson Snapdragon. I occasionally use the RAL system through PPG and in using Colorlock which is a German system for leather repairs so its nice to have some knowledge of what it is and the history behind it.
Unfortunately things dont seem to have changed in current times to colours changing shades from their reference numbers or codes, mismatching pigments and obsolete pigments being replaced with synthetic versions being only the tip of the iceberg.
Josh
When you go though the classic Ral codes, you will notice that in some areas numbers are missing and those, in most cases are the colours used during the war. The original field green/grey used for uniforms is not there as is some of the green and blue used on engines and OEM and field equipment.
The colours I use are taken from my suppliers archives and batch samples and matched to the equipment in the vehicles. Maybach engines are typically a very dark blue grey and some gearboxes are a green colour. Nothing seems written in stone apart from the basic interiors.
Two of the Panthers I have have manufacturers codes next to each other. they were side by side on the production line, but one of them has a dark blue/grey gearbox and drive train while the other has a green one. Both engines have the same dark blue/grey colour and the main gun sight on one is the tan brown RAL 7028 while the other is the 6003 green!
All the colours I use on the real vehicles are acrylic enamel and matched 100$ to original chipset/batch colours by computers. when on public display they appear to change colour thoughout the day and that is because of the daylight.
James
It seems like Vallejo revised their Dunkelgelb for the Model Air lineup according to the chips you sent them. Nice!
As far as I know, I think that Vallejo are working on a full Dunkelgelb set which will include all the official chipset shades from February 1943 to may 1945.
I am not sure when it will appear but in the interim, Afrika Korps shades can be used as substitutes as the shades are reasonably close and it not a stretch to see that these shades could and may have been used during supply shortages.
It was called Dunkelgelb, translated as Dark Yellow, but in actual fact the colours were tan, beige and brown/green. Do not be fooled by the name.
The shades would vary by 10% +/- by manufacturer depending on their ingredients which if you start with the correct chipset shade then you can lighten or darken etc as you wish.
Yes, Vallejo advised that they will be rolling out with new Dunkelgelb, but we’re still waiting. I’ve basically moved on to MMP versions…they spray great, but so does Vallejo when thinned with their flow improver.
be safe out there
Look out for press releases late this year, could be put back because of the virus and most of Europe is in lockdown!
Yeah, I’m looking forward to this set too!
On a side note, I found a Jagdpanther and Panther in running condition. Both were from Trier, Germany. The base coat is similar to the late-war variant of dunkelgelb. However, the camo wasn’t painted in chocolate brown but rather with something like dark maroon/violet similar to Vallejo 71.041 (RAL 8017; armour brown). It was different from what’s being shown in RAL’s webpage.
Don’t be fooled by your monitor settings, Geoff
These vehicles are painted correctly with the original shades found on the vehicle. The Chocolate brown is the correct RAL 8017.
What is probably throwing you off is the Dunkelgelb shade. Now all these colours are what is called “mimetic”. this means they “change colour” with the light. This of course is physically impossible. What it is really is our own brain, both concious and subconcious working to make out what we are actually seeing and the detail. this means that our brain wil subconsiously lighten or darken particular colours to make them and the detail stand out using our memory and the surroundings that we are seeing. If it is a bright sunshine day then the colours are lighter, if a dark cloudy day then the colours will be darker.
These are original chipset 7028 colours, painted to full depth on a white background on a cloudy day. They are posted in order of usage starting with Dunkelgelb Nach Muster then going with RAL 7028, Var 1, Var 2.
Depending on how your monitor is set with white temperature etc depends on just how the colours show.
Owners and restorers of original builders such as myself have not only access to the vehicles but also archives and some paint manufacturers who have a private agreement, especially in Germany to produce these colours, by using modern formulaes and translating from original formulae to the actual shades so we can use them in accordance with health and safety regulations. The paint I use comes from Germany and is a non- toxic acrylic paint from an OEM using their archives which has chipset and 10 slight shade changes for me to choose from (5 darker and 5 lighter from Chipset) These shades variants are within the 10% tolerance set by the OKW and which the manufacturers managed to keep to right up until the wars end.
Every paint batch is tested at the factory and computer checked with the original batch paint sample or chipset and the last delivery of RAL 7018 Ver.2, 6003 and 8017 had a variance tolerace of 0.01% from chipset for each colour. Our eyes and brain won’t even see that! Neither will it register anything much under 11% difference unless it is a very bright sunny day.
Every armour or soft skin that I start to restor begins with a complete was of the vehicle to remove all dirst and dust and is followed by a walkround both inside and out where paint samples are collected and sealed into plastic packets with colour and area of sample marked on the packet.
The vehicle is then stripped down as much as possible to its component parts. Paint samples are still collected from equipment that could not be accessed properly during the initial assesment and walkround.If the vehicle has zimmeritt applied then photos are taken of the patterns amd photogrammetary used to produce a complete vehicle pattern. Samples of the Zimmeritt are taken from different areas and labelled like the paint.
The paint is sent off to our paint manufacturer in Germany where they will test the colours and match to their archive chipset and batch samples and produce the closest colour that matches. the Zimmeritt is sent to a testing lab that produces a report on what materiels the Zimmeritt is made out of.
The vehicle and equipment is stripped back to the bare metal. EVERYTHING is taken off. Paint, Zimmeritt stencilling etc and the rebuild starts. Working from blueprints etc what is broken is remade, even down to getting a lens manufacturing company to remake the gunners sight for us for one Panther G. 99% can be done on our own repurposed machinery, lathes etc. What we can’t do is outsourced using a barter system. Our armour main guns are refurbished back to full use by Rheinmetall who actually made quite a few and our handshake agreement is that it is done as training of apprentices who get to work on a very famous piece of hardware. They are also well supervised and there is more than one employee who wants to work on these things!
By the time the vehicle rolls out of our large workshop (these things are not small) they are more or less factory fresh and it is all done by modern retired or injured veterans. The zimmerit is remixed using the original components and we apply to correct depth and pattern using wooden molds and the photogrammetary models.
I never put a timescale on the restoration. It is done when we are happy that it is right. Of course these things are 70+ years old and have issues all the time. Just like we veterans!
Nothing beats taking these down to be fueled up and having all the traffic get out of the way or having to form an orderly queue. they are 3.5 meters wide and 40 odd tons. you mess with these in your car and you will have some explaining to do to your insurer!
Yeah the lighting is indeed doing its work. I guess the Germans knew exactly what they were doing when they designed the three-tone camouflage. Impressive.
Sounds like you’re having a grand time restoring vehicles. Must have been a hell lot of fun working on and learning from restoring various vehicles. I’d love to work on one should I ever manage to have the resources to do so. Thanks a ton for sharing your expertise to the community!
