- The ‘Junkster’ Pod Racer
Hi all. It’s been a while since my last build. I have started on another build taking another break from truck building, while gathering thoughts for my next one. I have several in mind but I am trying to figure out which one to choose and how to proceed. 'Till then, I am working on a pod racer. Yes, another one. For some reason I have a think for these machines. I also planning on a big spaceship build after this build. We’ll see. Anyways, Here are pics of the progress so far. We will see how it turns out.
The concept of this build is simple. It is an older model that has been rebuilt from scrap using various metal and machine components, hence, the name, The ‘Junkster’. So It is going to be weathered to show the old age and extensive usage. Fits me just right.
- Most of you guys may already know what parts I am using here already. It’s from a 1/32 F-15E fighter jet. I had no drawings, just planning as I build. I have lots of parts(lots), as you can see in the pics blow:
- This will be the body of the engines. Or should I say the fuselage. As you can see, I’ve already started adding the details to it. Majority of the parts are taken from other kits. Makes things easy for me, as time is always of the essence.
Added a couple details under the both sides of the fuselage. I will not be adding a lot of details on the bottom as it will not be easily visible for viewing anyway. I also think the amount of detail on the fuselage already as it is on the underside is just right and does not need too much attention.
I’ve already painted on of the panels to test how it will look.
These particular panel doors were taken from a stryker model. I seem to have lots of these parts lying around back when I was scratch building AFV models.
The braking flap. This will be left in the open position as to give the entire model character when it finally placed on its mounting baseboard.
These will be the vents angled downwards. I added a little mechanism to both sides to give the impression that the vents can be folded upwards at right angle for a horizontal exit.
The covers added:
How it looks installed. Not looking all that great but inside of this is not so trivial to the end results.
My free hand cutting was not perfect but all this will be hidden in the final results.
The parts I chose to reprent the Electro Attachments.
Here are the parts disassembled and assembled just to give you an idea of the pieces involved.
Now the assembled piece. There will be one on each side of the pod.
