I did the Tamiya kit a while back and thought it was a nice kit.
I have the Hasegawa SBD-4 and was wondering if the sprues were the same except for the prop.
I didnāt receive it yet,next week,but I have nothing to compare it with,so I woukdnāt know,maybe Scalemates.
Scalemates didnāt have a review of SBD-4. It appears that the spinner is included on fret N I believe, but the prop is on a separate fret.
This may contain the information youāre looking for. A few years ago, Witold Jaworski was making a 3d model of the SBD and went through much information. It may take a bit of searching, but his research is good.
Gary
Well, it is a TBF-1 which was the type first flown in combat at Midway, FROM Midway. And it also is A āBlack 17ā, not THEE āBlack 17ā, LOL..
And that my friend, is the main purpose of the Group Build!
The one you posted all crumpled on the deck is a TBF-1. Those were all built by Grumman. Eastern Aircraft, or General Motors, didnāt start building them under license until the TBF-1C entered service. The GM built Avengers had the āMā inserted into the model as a code for GM. Any Avenger built by them would read TBM-1C, like that. They were virtually identical and very difficult to tell apart, and the GM versions were just as tough as the Grumman.
And a very nice kit too. I like the Hasegawa SBD when it came out.
That is a Hasegawa SBD-3, painted up to be the aircraft flown by Lt. Earl Gallaher of Scouting Six. Gallaher is credited with putting the second of four or five 1,000 lb bombs into IJN Kaga.
The SBD-3 and -4 were pretty much the same aircraft, except the prop and probably radios and avionics might have been approved, fuel capacity and stuff like that. You probably could use it but youād need a -3 prop.
Thinking of building the F2A-3 Buffalo that could be done in Marine livery or a Wildcat F4F3 that also could be done up in Marine Corps colors.
I took the kits up from the basement, which I am intended to build, to look through what I have and what additional to get.
For the US side of the battle, as mentioned before the TBD-1 Devastator, plus the Trumpeter USS Hornet.
For the TBD I have an ASK mask set, because of the greenhouse I might add a Quinta set for the interior.
For the Hornet I have additional aircraft and a Flyhawk wooden deck. I am ordering a Tom“s Modelworks PE detail set and 3D printed replacements for the guns.
To represent the Japanese side I will be doing the Eduard A6M2 Zero and Hasegawa Akagi.
The Eduard kit supplies everything needed, for the Akagi I have additional aircraft and the Tetra detail sets, generic and the deck. Like with the Hornet, I am ordering 3D printed replacements for the armament.
Looking forward to a lot of fun
The Tamiya kit OOB is an F2A-2, and OOB, will not work. The only kit I can think of OOB that will work is the Special Hobby F2A-3, which is marketed as a āBattle of Midwayā kit, and is also a Marine aircraft as they were the only ones flying them at Midway.
With the F4F you have a couple options. One being the Hobby Boss F4F-3 (Late), OR the awesome Eduard F4F-3. Iām not sure of the kit number but they would be later produced -3ās with a reflector gunsight, full cowl flaps and the upper cowl scoop.
You probably know all this dribble anyway, but incase you didnāt I hope this helps. If you do, then this goes into the āNothing to see here, keep moving onā¦ā fileā¦
This is a very ambitious build plan, but one I am looking forward to following, especially the two ships! I was thinking of trying my hand at IJN Mikuma, but I am not a ship guy and it would probably take me way too long to finish it.
Best of luck getting them all done and if starting a bit early can help than by all means have at it.
Wow! Now thatās an ambitious lineup! Four projects, including two aircraft carriers? Iām impressed, and maybe a little jealous! ![]()
You must either have a lot more time to build than I do, or youāre a whole lot faster. Probably the latter, since Iām notoriously slow. Iād probably spend a year on just one of those carriers alone!
Iāve been looking at building a modern Wasp-class amphibious assault ship someday, so Iām especially interested in following your carrier builds. Should be fascinating projects!
@fjs3 @Samphoto , I know this is an ambitious plan. These kits are lined up for some time, this GB is the perfect motivation to get building. I thought to have a PE set for the Hornet, obviousely not! Ships are not new to me, essential is good reference material. Still time consuming, but makes things so much easier! I still have five builds on the go which have to be finished until end of the year, another unstarted has to be finished until end of March. So yes, several builds at the time is not new to me, too. So far the agenda was empty for next year, which makes me confident to finish all five builds - including the F-4A Lightning for the Unafraid and Unarmed GB.
Thatās quite an agenda! Five builds to finish before the end of the year, another by March, and then five builds for the Midway GB. You definitely have a higher tolerance for multiple projects on the bench than I do. ![]()
Iām glad to see the F-5A Lightning is still in the plans for Unarmed & Unafraid too. Iām very much looking forward to seeing that unique aircraft.
Between the two group builds, it sounds like youāre going to have a very busy 2027.
And I agree completely about good reference material. The more Iāve researched my Dauntless for this GB, the more Iāve realized how much easier it is to make decisions when you know what youāre actually trying to reproduce.
Wait until I get retired in three years ![]()
Of course the F-5A - you know better what I am buiding than I do. ![]()
The five builds are almost done and for March next year is the Hasegawa Sabre - a doddle to build - in NMF, no complicated masking!
This one is in the line up too.
I wanted to build the SBD as well but with the prop in question I donāt think that it would be an option at this point in time.
I agree. For a specialized reconnaissance variant, 180 aircraft is a surprisingly substantial production run. Especially considering that the F-5A was just one of several photographic reconnaissance versions of the Lightning.
Iād change that sentence to āI was surprised to learn that 180 F-5As were built.ā That better reflects your reaction.
Actually, I knew very little about the F-5A until you mentioned building one for the Unarmed & Unafraid GB. Iāve been doing a little reading about it, and itās a fascinating aircraft.
I was surprised to learn that 180 F-5As were built, and that they were purpose-built reconnaissance aircraft rather than converted fighters. Five cameras in place of the guns, and the pilotās only real defense was speed and altitude. Apparently, these reconnaissance pilots were nicknamed āPhoto Joes.ā Those guys certainly earned their paychecks!
As a photographer myself, I have a particular appreciation for what those crews were doing. Imagine flying over enemy territory, completely unarmed, just to bring home photographs.
And as for your upcoming Hasegawa Sabre, I hope your decals are better than mine were. I ended up painting the theater stripes myself, which turned into some pretty complicated masking! ![]()
