The Basics Please....
I’m interested in getting an airbrush…never used one before…what should i look for…whats the advantage/disadvantage of compressor vs aerosol proppelant…etc…
For someone who’s never used one, I’d recommend a single action, either badger or aztek.
Single actions are extremely easy to use and allow you to experiment with an airbrush before sinking big money into something you might not enjoy. With a single action, pressing down on the trigger releases both air and paint. It’s basically a no-brainer. You don’t have to worry about controlling air-to-paint mixture like with a double action AB. You put the paint in the cup, connect to an air source and you’re off and spraying in no time. On the upside, they’re very easy to use. On the downside you have no control over the amount of paint. And because all single actions are external mix, the atomization isn’t as fine as with the DAs which are internal mix.
But practice for a few months with a SA brush and when you feel ready (and if you still enjoy using an AB), upgrade to a DA.
As for an air source, well, propellant is cheaper, but generally has a lot of problems. With constant use, compressed air will drop in temperature and turn into water until it warms up. That has a few inherent problems of it’s own. When the air pressure drops, you can’t shoot any more paint until it warms back up (plus you don’t really want to chance shooting water through brush and onto your project anyway). Also, they have no way to regulate air pressure which means you need to get a seperate regulator (though I’ve never seen anyone use one in conjunction with a can).
A constant air source (AB pump or a pump w/ tank (like the ones used for air tools)) are more expensive but are a one time purchase. Most have a built in pressure regulator so you can control how much air is getting to the brush. Some are quiet and some are noisy, but you never run out of air in the middle of a project.
That should answer most of your questions, but if you have anymore, feel free to ask.
-Fred
Start here:
http://www.swannysmodels.com/CJairbrush.htm for Montana Cowboy’s very excellent article on airbrushes, which is hosted at Swanny’s website, then move onto:
http://www.craigcentral.com/models/ and scroll down to Scott’s (AKA MusicCity) articles on airbrushes, air sources, paints and how to’s, some written by other FSM members (RLFoster and Stryene).
That should get you going in the right direction!
Edit Gigatron has provided some great tips, but he has erred on propellants. They only seem cheaper. It doesn’t take very long before you end up paying more than a decent compressor is worth. He is entirely correct in listing their short comings. IMHO propellants are to be avoided! /edit.
I would point out that not all single action AB’s are external mix - the Badger 200 series is an internal mix design.
Yep, in my haste, I left out “initially” as in, propellants are cheaper - initially…
Ehh, one day I’ll learn to proof read before I post [:I]
As for the badger 200, can’t say I’m familiar with that one. I know thay have an SA hybrid, which allows you to dial in the paint flow, but I wasn’t aware of an internal mix model. Learn something new everyday.
-Fred
I just ‘jumped into’ airbrushing. I did a bit of research. I finally found a good deal on a compressor with a tank, regulator, and water trap. The package included a Badger 150 Deluxe Kit.
Price and ease of use for learning is why I chose the Badger. Its been a year now and I’m still learning things, but I don’t get to spend near enough time to practice. [:(] I’m wanting to say that kit was about $300…if memory serves…but I am getting old. [:)] I hate CRS [:D]
To all of you…thanx alot…that should help…Now to persuade the Cheif Financial Advisor…my wife…
