WOOWW!!! Awesome stuff!!! You must have years wrapped up in all those fantastic builds!
**Eric, Gordy and Dan:**Thanks alot for the encouragement! Gordy I don’t know what size wire it is but I can measure it and find out. I do, however, know this- I have to give my eyes constant breaks. One thing is for sure! I aint in my dang 20’s or 30’s anymore!!! [:O]
I sanded the other side of the 51 Chevy and then re-shot the body with primer. I still have a few pesky spots to sand but I should have it all evened out this week.
I cleaned up the 37 Ford and primed it this morning and then shot the hot pink pearl and gloss black tonight after I got back from Nashville. I also painted the frame. I like this color combo hehehehe.
I’m still waiting on the hood for the Impala so I can get them primed and painted.
Well this morning I spent tinkering around with the voltage regulator a little more and working on the brake line fit with the master cylinder mounted up. Anytime I do alot of mods / additions to my builds I always make sure to have a spare kit close by for stuff like this (in this case I have two spare kits! lol).
With the master cylinder mounted up in the body, the lines needed a whole lot more tweaking to wind up in the right place on , or in this case, in the frame. I found out that I had to bend the lines more towards the center of the car at the point where they exit the master cylinder. I had to make some other pretty big adjustments to them and still have a little ways to go but here’s the mock up:
Doh! I have too many threads open, yours was the last post before mine and you know, the mind-she goes first. lol Sorry to Freakshow for sliding your credit over to Mopar but still, well done.
Mopar -thanks for the pics. Those trucks are great. The green utility truck is really cool and I love the Mopar delivery rig. Great stuff. Are all the car hauler trailers custom scratch builds? That is so much cooler than a diorama I was thinking of using to display with. You can display so many more kits too. Awesome.
Thanks Gord the gray transporter is the AMT 5 car hauler and the blue one is the Revell 6 car transporter. Both of the trailers are on eBay but usally go for over $100. It looks like Revell may be reissuing there car transporter this year. I hope they do and maybe Hobby Lobby will sell them.
Joe I stared back building trucks in 2008. I built a bunch of them back in the 70’s but they are all long gone now. Your brake lines look good I’ve used a soft wire for brake lines to make them bend easer in the tight area. I don’t remember where I bought the wire.
LOL! No worries on that!! I think sometimes that’s all HL sells is AMT and Revell. I long for the days of choice Tamiya kits again and not the crappy Tamiya ones they have now. Don’t get me wrong , HL’s AMT and Revell selection in cars is just awesome. Their aircraft selection however, sucks canal water! lol
On a brighter note if HL does in fact end up selling them and you get your hands ahold of one Dan, it’ll be a knock out build!!
About all I did today was clean parts, but the 37 was dry enough for a test fit. This will give an I dea of how it’s gonna look. I thinks I like it hehehehe. Still haven’t decided on an interior color yet.
Looks good so far Eric. Colors that come to mind are a lighter shade of purple with black and white trim, Cherry red or black. Good luck on the choice though.
Folks I’m going to try something totally new to me today as it’s been weighing on my mind about how to replicate a mummified (a.k.a. tapped/wrapped) wiring harness. It’s all in the experimental stages now and I may have to switch to a slightly smaller gauge wire to accommodate the scale thickness to my build here but here goes.
First I start with two strands of wire clamped at one end by my table vise and two strands of much thinner wire. Then I gather my tools and materials:
I didn’t get pics of the initial process but I think you’ll get the jist here. I used the lockwire pliers to put neat wraps in the wire and took the two much smaller pieces of wire and inserted into the wraps at about the midpoint and continued the wraps until it was fairly tightly wound. I then applied a bead of super glue along the length of the wrapped wire set. At that point I cut a strip of the teflon tape and started wrapping the twisted wire set like I would with electrical tape. To get this:
I continued on until I ran out of tape and, unfortunately, time this morning but this is where I’m at right now. Will continue onwards tomorrow morning and have the four wires as breakout circuits for the ballast resistor and the wiper motor. Again I’m probably going to have to go with smaller gauge wire but I’ve got the thought process down to application now anyways
a little closer…
I do see myself adding more super glue to the wraps to keep it from looking so much like wrapped twisted wire but we’re getting there.
Joe this is a great method to create the wire harness I would of never thought of using Teflon tape to wrap the wires A little black paint and they will look perfect
just a little update on the truck I’ve added a spare tire to the inside headache bar and a couple more gussets
Hmmm…dunno. I’m gonna be quite a while on the Hind, me thinks, then i’m back to the USMC GB, then probably right after that, the Artillery GB…I’m tapped out, oh, then hopefully on to the 1945GB…geez, I am quite committed…[8-|]
I agree with Mopar, the Teflon tape is brilliant! One suggestion I might add though is to run the wires parallel to each other as they are in a harness instead of twisted. I think it would make it easier to wrap and also wouldn’t have the curves showing from the twists.
Dan: I forgot!! Nothing sticks to teflon tape. Crap! Scratch the teflon tape idea…but I think I have another idea. We’ll see. Spare tire looks great in there!
Rob: Man do I ever understand that! There are times (far and few between) where I feel like I’ve overcommitted myself with GBs but then I remember that I’m handling it ok and only building in one GB at a time. Our paths may yet cross again down the road. I will say that your input is welcome here anytime pal.
