Well, a friend of mine found out that i do models and he said that his dad use to and then gave me his airbrush. An old Thayer & Chandler and I believe this is a model A. Serial number is there, but that does not help.
Now I got some Paasche airbrushes, Harder & Steenbeck and an Iwata, but you know when you have a passion for something and then something old comes your way I had to accept the gift.
It is very small compared to the airbrushes mentioned. It is a side feed, the air hose connection is very small. I did look it up and there is a guy in an old video that has exactly what this is. Video called 1920’s T & C so could it be?
So I tried it out and something was not right; the trigger was tight so I opened it and it looks like his dad crushed the Tube where the needle goes in. No way to save it, but I finally got the piece out.
Looking around I found a thread that said the Badger 100 is basically the same thing. What I wonder is that tube piece. I found the Badger part at this site
https://www.midwestairbrush.com/ba100seaipa.html
Part 50-030 is the part I believe is similar. The thing I noticed on the broken one is that it is keyed to line up with item simliar to 51-011. T & C one is different than the 51-011, so my big question is;
Does that piece from the Badger 100 part 50-030 work on this T & C and is it keyed? Keyed meaning at the right end of part 50-030 on the T & C is round, but at the left end it is almost a half circle where the needle tube goes in to. From the damage I saw I believe his dad smoked it down so tight that the right end bent (can see teeth marks suspecting a pair of pliers were used)
So I would like to get this old piece of history working again, so far the above site is the only one I found that has been referenced to be able to use some parts.
The needle was also bent and I tried straightening it out, but again, if the parts of the Badger 100 can be used I wonder then if the parts list will work. I know I am asking a lot or maybe someone here knows of a different airbrush parts store that carries the parts. So looking for some help to see if I can bring this back to life. Here is the video of the guy using what is the closest to what I acquired. The end that is black is more tappered on mine than what he shows, but other than that it looks identicle.
Thanks everyone
https://www.youtube.com/watch?v=iO-gqmckooc
Update - I found a picture of the airbrush and the needle tube, but I cannot find the tube that screws in to the airbrush body.
Airbrush
Needle tube (you can see there is a flat side. Tube is keyed for this piece)
