Thanks for the airbrush advice
Now that I’m ready to purchase 1,having narrowed it down to a few 2 stage models recommended by you all,Will someone explain the pros & cons of gavity vs. siphon feed ? Armed with this last bit of info along with the rest of all you folks ideas,I can make my final choice. Semper fi, rudedog
Not an expert, but from reading here the primary advantage of gravity feed is the ability to spray at lower air pressures, which means finer lines.
