Testors White Decal Paper
Hi pals, the Testors white decal sheets are working exactly the same as the clear ones do: Totally translucent and clear. I am working with the same technique as with the clear ones I never had any problem with.
I am doing something wrong? The decal does not slide off with any white background.
Regards!!
You might have a bad batch, probably mis-labled white but are in fact clear. Contact Testors to see if they will replace it.
I agree. I’ve used their white sheets before with no issues. I’m thinking it’s a bad batch you got. :frowning:
Eric
