Testors 1/48 OV-10A Bronco
OK gang, I like having more than one project on my bench at a time. As you may know, I have a Testors (Hawk) U-2 nearing the finish line. I’m building this Testors (Hawk) OV-10A along with it. Yes, I know ICM has put out their new Bronco wunderkit, but I had this gem already sitting in my stash. Yes, I’m aware of all the issues and niggles with the kit, but I’m sure it’ll look like a Bronco when it’s done and on my shelf, and that’s good enough for me. The kit, with all of its challenges, will serve as an opportunity to hone on my skills.
I started with the cockpit. This old kit is very basic. There is NO detail in the cockpit or wheel wells. There isn’t even a control stick! This should give you an idea of what I’m working with…
Because of the big greenhouse canopy, I figured I needed to add something to reduce the void, even if it’s not accurate. So, to that end…
I started with gluing a piece of styrene backing to the forward part of the tub to avoid being able to look down through the canopy and out through the nosewheel well. To that, I glued one (of many) pine derby car weights.
I also boxed in a small area behind the instrument panel face and under the glare shield with some styrene, then filled it with some Liquid Gravity. I also glued in more pine car weights.
I also added some styrene strip to the cockpit sidewalls, just to add some detail. The nose wheel assembly is supposed to be installed prior to the fuselage halves going together, but the assembly isn’t very sturdy, and I was afraid it’d get broken off during assembly. In an effort to avoid that, I modified the nosewheel assembly.
I drilled through the mounting assembly and into the struts. Then I cut the struts and wheel away from the mounting piece. My goal was to use some styrene rod as a way to “pin” the assembly back together later in the assembly process. It looks like it might work.
Once the wheel assembly was separated, I was able to glue in the mounting piece. Here you can see it in place, along with some more of the weights.
Real Broncos have a rear seat, and cockpit section is open to the cargo area behind the rear seat. Unfortunately, the kit does not include a rear cockpit. This was a bit of a blessing, because it allowed me an opportunity to add more weight. I had some half-round weights that I painted up to look like cargo. Using some Tamiya tape, I made some straps to secure the cargo. Also, I used some styrene sheet to make a rear bulkhead. Using some more weights and wires, I built up some electrical boxes for the back of the fuselage. Lastly, a Band-Aid was cut up to provide a “cushion” for the seat, and more tape provided for seatbelts.
By no means is my Bronco going to be accurate, but at least there’ll be something under the canopy to draw the eye. Oh, and all that weight should keep it on all three wheels. I just hope my nosewheel assembly will hold up.
Once the interior was done, I decided I’d build the airframe as two components. I decided to build up the wings and booms as one assembly, and the main crew cabin as a second separate assembly.
This made cleaning ups the seams much easier, and it will make painting easier, too. The fit of the two assemblies is pretty good.
Once things are ready to go together, there are only two small seams on the upper surface of the model. These will be easy to deal with and touch up.
The seam on the underside of the wing where it meets the fuselage is nonexistent.
My plan is to paint the camo on all parts except the upper joints of the boom and cabin assemblies. I’ll leave that part unpainted so that I can clean up the seam and touch up the paint. Speaking of paint, I got the two big pieces primed in Mr. Surfacer 1500.
The coverage isn’t perfect because I just misted on a coat to see what spots still needed to be kissed and caressed. I have a little cleaning up to do before everything gets an even coat of primer, and eventually, paint.
Anyway, that’s where my Bronco’s at. I appreciate you stopping by. Comments, questions, and criticisms are welcome. Feel free to drop you two cents into the bucket on your way out.
Stay tuned!
-O
Lot’s of progress there O. Sure looks like a Bronco with that rectangular wing and distict canopy. Are you planning to finish like the box art?
I love the Vietnam War era OV-10s! Your progress is looking so good and “Kudos” to you for building this “Vintage” Testors kit when a newer kit is available.
Hey keavdog, no, my plan is to build a USAF airframe from the 27th TASS. The box includes the decals for one, so that’s what I’m gonna do. Hopefully, if the decals hold up, it should look something like this:
Thanks to everyone for the compliments. All the pats on the back help keep me motivated.
I’ll post more when there’s more to post.
Cheers!
-O
Oh that’s going to look awesome.
Following this build with great interest!
Love that paint scheme! If my memory is correct, I believe that FSM’s very own Paul Boyer flew in Bronco’s during the Vietnam War. Paul, I apologize ahead of time if I’m wrong about that.
OK gang, I’ve had some time at the bench and spent it plugging away at my Bronco.
When I last left you, the main assemblies had been primed and were waiting for some additional attention. I got the few blemishes cleaned up then primed a second time. After that, I lightened the panels’ centers to add some depth to the following paint layers. If you notice, the tips of the tails have been covered in white because I’ll be spraying them yellow for the 27th TASS.
Then I started spraying the camo colors, starting with the medium green…
Then followed with the Euro green…
Then finished with the gray.
In the photos above, the parts are just dry-fitted together. The two big unpainted spots on the spine are where the crew cabin connects to the wing assembly. I left them unpainted because I’m going to clean up the seams. That’s the next step.
Anyway, that’s where things are at with the Bronco. As usual, comments, questions, and criticisms are welcome. Drop you two cents into the bucket on your way out.
Thanks for popping in for a look!
-O
Love the prep work/ color modulation you put on this one Omar. Will be watching for the next updates after the seam repairs.
That looks great O. Really nice tonal variation.
Great work on the camo O! :+1:t3::+1:t3:
Killer paint job sir!
Fantastic job on that camo scheme! This is going to look amazing when it’s finally completed.
Great looking paint job on that Bronco. Looking forward to seeing her all done.
Well…wait no longer!
First, thanks for the encouragement and compliments. They’re both greatly appreciated. As it turns out, I was able to get the seams tackled.
To start, I actually enlarged the rear seam. Yep, you read that right. I widened the gap. The point was to use a piece of sheet plastic to act as filler and to push the parts together at the forward seam. Once that was done, I glued in a piece of scrap…
Then removed the wing section and shaped the plastic to match the fuselage’s contours.
After some careful dryfitting and a kiss of Mr. Surfacer, both seams turned out nicely. Here they are after some touch-up painting.
And this is the fuselage with the camo painting done.
So, this is where we’re at with the Bronco. Next will be gloss and decals. While the gloss and decals settle and dry, I’ll focus on the props and undercarriage.
That’s it for now. I hope you enjoyed the update. As usual, comments, questions, and criticisms are welcome. Feel free to drop your two cents into the bucket on your way out. Thanks for lookin’!
Happy modeling!
-O
And just like that, poof! No more seams!
That is a technique that I picked up several years ago from a fellow modeler on here.
