Test PhotoBucket
Fujima F7U Sprues 3
Hopefully you can see the airscoops that were opened up. These are very prominent on the real aircraft
Just right John,lookin good.[t$t]
Tony Lee[:)]
Good Morning Tony,
Thanks for the input. I just wanted to be sure I was attaching photos correctly. My first try was not what I wanted.
Have a great day.
John
PHOTO TEST…
cool it worked, managed to bypass photobucket…
Julez72, How did you bypass photo bucket? I would like to do the same.
John
He “Hotlinked” it. ie he linked direct to the original picture instead of hosting himself. Some consider poor form at it forces the originator to pay for your bandwidth use.
Andrew
Testing…
Not at all sure what the heck but
#1 is the Insert Media button
[View:/themes/fsm/utility/:550:0]
#2 is the paste button
so far I’m underwhelmed[+o(]
Ideas Any One??? OK! It just dosent show up on PREVIEW!! NOW WE’RE ROLLIN’[blns]
testing
Every now and then someone finds something wrong with a WordPress install which, rather than be caused by a bug in WordPress itself, is caused by a server configuration error, an interaction between WordPress and something else installed on the server or is just a recommend optimisation for better site performance.
Everyone has a different set of pitfalls that they have come across and I would like to collect together all these little things into a comprehensive community developed plugin which can hopefully become one of the first “canonical” plugins that we have talked about.
To that end I have developed a framework for this plugin, in the style of a unit test framework, to make it really easy to write tests and I am hoping that some of you will have ideas for tests and also that you will want to get involved.
For a while I have tagged tickets in the main WordPress trac where there are is possible inspiration for tests
Noise Cancelling Headphones| SEO Agency
