This was very much a project filled with learning experiences, unsurprising considering that it’s my first model.
I was originally going to try and be a bit more historically accurate with it and use a desert color scheme but then, without thinking, I primed it with black. With that I figured why waste the paint throwing on 4 or 5 coats and just used a dark blue/grey instead, although that also turned out to be too dark for my liking.
After that I covered the tank in a brown acrylic wash, something that made me very nervous as I’ve heard it can be pretty difficult to work with but all in all I think it turned out pretty good. It gave everything a nice dirty effect, though if I use it again I’ll have to darken it up a bit.
I got a bit experimental near the end of the build. The rust patterns covering the back of the tank were done using acrylic and a frayed brush, which turned pretty out pretty good but look out of place since i didn’t want to get too overzealous and cover the whole tank. The horrible light blue chipping I attempted on the front is the only thing I’m not too happy with on this one.
Finally, I gave all of the rivets and tools and such a brown oil pin-wash (the detachable armour got a full wash) that really helped tie everything together. I’m particuarly happy with how the commander figure and the shield in front of him turned out.
Thanks for checking it out, and any critiques or tips are welcome!
For your first model, your off to a good start. There is plenty of time to worry about historical accuracy. You can prime with black and use lighter colours underneath. I do all my aircraft black even the blue undersides.
Would i be right in thinking your useing Tamiya paints.
No, I’m a bit scarce on resources and bought whatever was available at a reasonable price for what you got. Being unsure of what colors I’d be using I just got a set of 18 2oz. Apple Barrel acrylics on Amazon for 20 bucks. I figured it was a good little starter kit just to see what’s what. I thought they handled just fine.
Ok, wel, thats something else you can build up as you go, along with referance material. If you can get a light buff colour, you can thin it a lot and spray a couple of coats and that leaves a good dust effect. But keep it light, the effect increases once it dries. My rule is, if i think it needs one more coat, leave it and let dry.
