I’m stuck on step one I can’t figuer out the poly cap it looks like it is suposed to go inside the weel and have another small pice go overtop of it but it dos’nt work the poly cap dos’nt fit into the weel and the pice just looks wieard over the weel has anyone make this kit if so pleeeeeeeaaaaassssse help me.
Are you using the right size polycap? The idler wheels use the small (short) polycaps and the drive sprokets use the large (longer) polycaps. I’ve built this kit twice and haven’t had any problems. Let me know if you still do.
Jesse
Your right I was useing the wrong cap but I couldint see the diferance but now that I look harder I do see a diferance gez I’m a dunce[D)]… note to self use eyes next time I run into a probelm with small parts
Thanks I probibly would never have figured that out[
Glad your poly cap problem is solved! I’m building the same kit for the “Liberation of Western Europe” Group Build. I just started last night. Post photos if you can, I’m looking forward to seeing your finished build!
