Squadron has the 1:48 Lancaster on sale and I’m thinking of getting it. I’m wondering if anyone knows if the plastic is black or grey on it? I herd the rerelease is grey but I’m not up to date on releases and rereleases.
Thanks, I think I found something that says it should be grey. I have the mosse in black plastic and it seems like black would be harder to work with than grey.
More than likely. It’s a newer run so it might have a new color plastic. And you are right, grey would be easier to work with. Good luck and post pics when you get it!
I’ve built it, it’s grey if its a re-release, good kit except the engines require a lot of filler to get the cowlings to blend to the wing, otherwise its a great kit!
