tamiya filler and masking tape....???
Hi…I used tamiya filler to fill small gaps and used masking tape so that not to fill other details. When I sanded smooth the filler I noticed that the plastic where the excess filler dried , had whitened. When I sprayed over it, it left like a straight line where the masking tape was. I have removed all the excess filler.
Ever Happened to you? I have used this technique on other models but It never happened to me…This is a trumpeter kit…could it be the type of plastic they use?
Regards Andrew
See Swanny’s technique for applying putty to seams.
http://www.swannysmodels.com/Seams.html
Thanks Airmaster
And here are somemore tips you might want to take a look at too
http://www.finescale.com/FSM/CS/forums/629986/ShowPost.aspx
Bud
