Tamiya Acrylic Thinner - MIA
Is it just me, or is this stuff disappearing? Noe in the shops in my area for quite a while, Great Models is out of stock… What’s the deal?[:S]
plenty down south[:D]
Whew! Thanks. None to be had in Vegas, and I’ve been waiting a while. Do you have any online sources?
before the earthquake Acorn had heaps. Acorn is now closed due to being inside the cordon.
Talked to local shop today - there is something going on with certain Tamiya paints, etc. Some blah blah about chemicals, packaging, blah blah. Bottom line, I gots no thinner. This guy recommeded using windex.
I use windex to clean my brushes but alcohol to thin for airbrushing if I cant find Tamiya thinner…
good luck[;)]
Carlos
Thanks, Carlos. I’ll try it tonight!
I’ve used a online company called etamiya.com, I live in the UK and Tamiya thinners was a problem for me to get as well.
The delivery and packaging was really good, I ordered alot of supplies as Tamiya products like thinners can be hard to come by.
Hope this helps.
Darren
You can use either Isopropyl or denatured alcohol as a substitute. You may need to add a little acrylic retarder to your mix (it’s recommended to mix it with the alcohol first before mixing with the paint.
You can find acrylic retarders at art supply stores.
You may find, if you use gloss Tamiya acrylics, that when thinned with alcohol, you may not achieve a full high gloss finish. It’s not a problem with the flat colours though.
Don’t use Windex as a thinner.[;)]
Roger that. Thanks!
